Hello every one, first post ever on this amazing forum.
Total newbie.
This is the idea: integrating a sonoff 4chpro to command 4 independent bulb. Up to today, Each bulb is normally tuned on or off by a relay (so I can use 3 different button to turn on and off the light)
Reading here and there, the most simple solution that is to use the sonoff as a button (itching mode).
In this scenario (please correct me if I’m wrong) HA will never get to know the state of the bulb.
Second option: substitute the existing relay with the sonoff and using the existing button by connecting them to the different GPIOs of the sonoff.
CONS:
- I canno’t find any instruction/video/pics.
- Safety…
- the Sonoff relay will be used a lot, since every time I turn on a light the relay is activated.
Do you have any other idea?
EDIT: I have hass.io running on PI3 and the sonoff is tasmotized.
