I want to add an external antenna for the Sonoff. There seems to be no possibility for an ipex connector. Is it still possible to attach an antenna and where to add?
it is esp powered normally, so this link might answer your question:
How to add an external antenna to an ESP board - ESPHome - Home Assistant Community
You need to connect to pad before pcb antenna, not to tail of it. And cut the trace to that pcb antenna.
