Just got a few sonoff thermostats, Pretty new to HA but got quite a lot working
want a compact card on HA.
I can add each entity & it works OK but when I try to use the simple thermostat or mushroom climate for a neater smaller option I can’t as no suitable entity. Seems need to start with climate.xxx
As is it sensor.sonoff_xxx_temperature not available.
May be a better way or I can get around but interested to know why.
Would like in as narrow, mostly horizontal car as below.
23 degrees : Up 24 degrees Down (or slider) : On/Off (indicatior)
Thanks I/A
Many thanks
That looks just what I wanted
I need to research myself as only just noticed but the sonoff docs seem to imply that there might be entities to set the actual sonoff climate/thermostat settings. i.e. the build in temp setting to turn on & off. They are not visible at the moment so perhaps I have got that wrong
This would be marginally preferable if there was problem with HA or even LAN power failure they would carry on independently.
Thanks again
