I have upgraded to ESPHome 2022.2 (and 2022.3) and since then my Sonoff B1 is “broken”. It permanently glows violett if everything is turned off. The cold white and warm white channel is only controllable as long as the RGB channel is in the on state.
I don’t think so, I have never seen any errors in the log - here the log from a short test:
Time level Tag Message
22:56:30 [D] [light:084]
Transition length: 3.0s
22:57:22 [D] [sensor:124]
'Wohnzimmerlampe Uptime': Sending state 2.89937 minutes with 0 decimals of accuracy
22:57:23 [D] [sensor:124]
'Wohnzimmerlampe WiFi Signal': Sending state -46.00000 db with 0 decimals of accuracy
22:58:22 [D] [sensor:124]
'Wohnzimmerlampe Uptime': Sending state 3.89937 minutes with 0 decimals of accuracy
22:58:23 [D] [sensor:124]
'Wohnzimmerlampe WiFi Signal': Sending state -43.00000 db with 0 decimals of accuracy
22:59:22 [D] [sensor:124]
'Wohnzimmerlampe Uptime': Sending state 4.89940 minutes with 0 decimals of accuracy
22:59:23 [D] [sensor:124]
'Wohnzimmerlampe WiFi Signal': Sending state -45.00000 db with 0 decimals of accuracy
22:59:28 [I] [ota:105]
Boot seems successful, resetting boot loop counter.
23:00:22 [D] [sensor:124]
'Wohnzimmerlampe Uptime': Sending state 5.89933 minutes with 0 decimals of accuracy
23:00:23 [D] [sensor:124]
23:01:22 [D] [sensor:124]
'Wohnzimmerlampe Uptime': Sending state 6.89938 minutes with 0 decimals of accuracy
23:01:23 [D] [sensor:124]
'Wohnzimmerlampe WiFi Signal': Sending state -44.00000 db with 0 decimals of accuracy
23:02:22 [D] [sensor:124]
'Wohnzimmerlampe Uptime': Sending state 7.89937 minutes with 0 decimals of accuracy
23:02:23 [D] [sensor:124]
'Wohnzimmerlampe WiFi Signal': Sending state -42.00000 db with 0 decimals of accuracy
23:03:22 [D] [sensor:124]
'Wohnzimmerlampe Uptime': Sending state 8.89938 minutes with 0 decimals of accuracy
23:03:23 [D] [sensor:124]
23:04:22 [D] [sensor:124]
'Wohnzimmerlampe Uptime': Sending state 9.89937 minutes with 0 decimals of accuracy
23:04:23 [D] [sensor:124]
23:05:22 [D] [sensor:124]
'Wohnzimmerlampe Uptime': Sending state 10.89937 minutes with 0 decimals of accuracy
23:05:23 [D] [sensor:124]
23:06:22 [D] [sensor:124]
'Wohnzimmerlampe Uptime': Sending state 11.89935 minutes with 0 decimals of accuracy
23:06:23 [D] [sensor:124]
23:07:22 [D] [sensor:124]
'Wohnzimmerlampe Uptime': Sending state 12.89938 minutes with 0 decimals of accuracy
23:07:23 [D] [sensor:124]
23:08:22 [D] [sensor:124]
'Wohnzimmerlampe Uptime': Sending state 13.89937 minutes with 0 decimals of accuracy
23:08:23 [D] [sensor:124]
23:09:22 [D] [sensor:124]
'Wohnzimmerlampe Uptime': Sending state 14.89940 minutes with 0 decimals of accuracy
23:09:23 [D] [sensor:124]
23:10:22 [D] [sensor:124]
'Wohnzimmerlampe Uptime': Sending state 15.89937 minutes with 0 decimals of accuracy
23:10:23 [D] [sensor:124]
23:11:22 [D] [sensor:124]
'Wohnzimmerlampe Uptime': Sending state 16.89937 minutes with 0 decimals of accuracy
23:11:23 [D] [sensor:124]
23:12:22 [D] [sensor:124]
'Wohnzimmerlampe Uptime': Sending state 17.89937 minutes with 0 decimals of accuracy
23:12:23 [D] [sensor:124]
23:13:22 [D] [sensor:124]
'Wohnzimmerlampe Uptime': Sending state 18.89933 minutes with 0 decimals of accuracy
23:13:23 [D] [sensor:124]
23:14:22 [D] [sensor:124]
'Wohnzimmerlampe Uptime': Sending state 19.89940 minutes with 0 decimals of accuracy
23:14:23 [D] [sensor:124]
23:15:22 [D] [sensor:124]
'Wohnzimmerlampe Uptime': Sending state 20.89933 minutes with 0 decimals of accuracy
23:15:23 [D] [sensor:124]
23:16:22 [D] [sensor:124]
'Wohnzimmerlampe Uptime': Sending state 21.89938 minutes with 0 decimals of accuracy
23:16:23 [D] [sensor:124]
23:17:22 [D] [sensor:124]
'Wohnzimmerlampe Uptime': Sending state 22.89937 minutes with 0 decimals of accuracy
23:17:23 [D] [sensor:124]
23:18:22 [D] [sensor:124]
'Wohnzimmerlampe Uptime': Sending state 23.89940 minutes with 0 decimals of accuracy
23:18:23 [D] [sensor:124]
23:19:22 [D] [sensor:124]
'Wohnzimmerlampe Uptime': Sending state 24.89938 minutes with 0 decimals of accuracy
23:19:23 [D] [sensor:124]
23:20:22 [D] [sensor:124]
'Wohnzimmerlampe Uptime': Sending state 25.89935 minutes with 0 decimals of accuracy
23:20:23 [D] [sensor:124]
'Wohnzimmerlampe WiFi Signal': Sending state -41.00000 db with 0 decimals of accuracy
same here. With other problems already described here
No way to add MIFLORA and other sensor after last upgrade. If I add sensor log becomes full of json error and board disconnects itself from wifi
Current version: 2022.3.2 doesn’t solve issue
I’ve got 2 sonoff basic r2 devices, both wouldn’t connect to wifi anymore after recent update of esphome (and updating the devices accordingly).
After some searching/experimenting with one device, and the many painful serial flashing over UART, I got it online again a few times.
I had to remove/comment a lot of the components.
Wanted to chime-in that I observed something similar to the original posted, here are the symptoms:
Two Sonoff B1 light bulbs flashed with ESPHome, both working fine for several months (but I don’t remember which ESPHome version was running on them)
Recently updated both to ESPHome version 2022.8.3
Since then, every now and then when they turn-off, they don’t switch the RGB channel completely off, it remains glowing faintly with a violet color
Usually turning it on and off again will do the trick and shut it off, but sometimes it is necessary to do it two or three times before the bulb is really off
I have not noticed anything strange with the brightness sliders in Home Assistant, but I also don’t tweak them much (these two lights are primarily driven by automations)
The logs don’t display any errors or warnings (logger level is set to DEBUG)
The lights are using the default 1s transition time fading anymation
In case it helps, this is the YAML currently flashed to both Sonoffs:
Hi @pw-sys wondering whether you manage to figure this out?
I’ve seen this issue too, but it’s not deterministic, happens maybe every 10th time the light is turned off.
I am considering adding a on_turn_off action to set all channels’ brightness to zero as an experiment, BUT I first need to learn how to save the previous state in-memory before doing this.
For whatever it is worth, I’ve noticed that it is easy to reproduce the “dim purple glow” issue on the Sonoff B1 by enabling the “restart” switch in the ESPHome template and restarting from Home Assistant.
As a workaround, I’ve added an action to turn the light on and then off again at reboot, which so far have resolved the issue with the purple glow (but notice that if your HA crashes and does not connect anymore to the API, the device will enter a reboot loop and this action will hinder using the light without HA)
unfortunately this is not fixing my problem, yes I can script it this way, but for me being able to control the white channels the RGB must be on, which results in a dirty looking white and a turn on delay of a second is unusable.
My short term solution is - I have changed my B1 for OSRAM zigbee bulbs.
