Hi everyone,
I’m trying to change from Tasmota to ESPHome in the wall switch I use in the kitchen. The sonoff is installed inside the box, and then it’s wired to an external switch with GPIO14.
I flashed it and have tested all kinds of configurations… but I can’t make the external switch to work! Everything else is working fine and if I click on the Sonoff button the relay toggles fine from on to off, as well as on Home Assistant config.
This is the config I have right now. Any help, please?
binary_sensor:
- platform: gpio
pin:
number: GPIO0
mode: INPUT_PULLUP
inverted: True
name: "Sonoff Basic Button"
on_press:
- switch.toggle: fakebutton
- platform: gpio
pin:
number: GPIO14
mode: INPUT_PULLUP
inverted: True
on_click:
min_length: 50ms
then:
- platform: status
switch:
optimistic: true
turn_on_action:
- switch.turn_on: relay
- light.turn_on: led
turn_off_action:
- switch.turn_off: relay
- light.turn_off: led
- platform: gpio
pin: GPIO12
output:
- platform: esp8266_pwm
pin:
number: GPIO13
inverted: True
light:
- platform: monochromatic
name: "Sonoff cocina Green LED"
output: basic_green_led
- platform: wifi_signal
name: "Sonoff cocina WiFi Signal"
update_interval: 60s
- platform: uptime
name: "Sonoff cocina Uptime"
text_sensor:
- platform: version
name: "Sonoff cocina ESPHome Version"
