Hi, I have a Sonoff Basic with MCP23017, two I2C temperature and lux sensors, plus an HC-SR501motion sensor on D0 of the MCP23017, configured as ‘sensor29 0,2,0’.
the issue I am having is that when motion is detected, the console gets spammed with MQT data. I want the motion sensor to detect and react to a motion event as quickly as possible (I want to activate the lights via HA automation), but instead of getting a single MQT event, I get loads. Is this normal, if not what am I doing wrong here please?
Below is a sample console output:
09:45:36 MQT: stat/sonoff11/RESULT = {“Event”:“Done”}
09:45:36 MQT: stat/sonoff11/RESULT = {“Time”:“2019-01-27T09:45:36”,“MCP230XX_INT”:{“D0”:1,“MS”:50}}
09:45:36 MQT: stat/sonoff11/RESULT = {“Time”:“2019-01-27T09:45:36”,“MCP230XX_INT”:{“D0”:1,“MS”:51}}
09:45:37 MQT: stat/sonoff11/RESULT = {“Time”:“2019-01-27T09:45:36”,“MCP230XX_INT”:{“D0”:1,“MS”:50}}
09:45:37 MQT: stat/sonoff11/RESULT = {“Event”:“Done”}
09:45:37 MQT: stat/sonoff11/RESULT = {“Time”:“2019-01-27T09:45:37”,“MCP230XX_INT”:{“D0”:1,“MS”:49}}
09:45:37 MQT: stat/sonoff11/RESULT = {“Time”:“2019-01-27T09:45:37”,“MCP230XX_INT”:{“D0”:1,“MS”:51}}
09:45:37 MQT: stat/sonoff11/RESULT = {“Time”:“2019-01-27T09:45:37”,“MCP230XX_INT”:{“D0”:1,“MS”:50}}
09:45:38 MQT: stat/sonoff11/RESULT = {“Event”:“Done”}
09:45:38 MQT: stat/sonoff11/RESULT = {“Time”:“2019-01-27T09:45:38”,“MCP230XX_INT”:{“D0”:1,“MS”:51}}
09:45:39 MQT: stat/sonoff11/RESULT = {“Time”:“2019-01-27T09:45:39”,“MCP230XX_INT”:{“D0”:1,“MS”:50}}
09:45:39 MQT: stat/sonoff11/RESULT = {“Event”:“Done”}
09:45:39 MQT: stat/sonoff11/RESULT = {“Time”:“2019-01-27T09:45:39”,“MCP230XX_INT”:{“D0”:1,“MS”:51}}
09:45:40 MQT: stat/sonoff11/RESULT = {“Time”:“2019-01-27T09:45:40”,“MCP230XX_INT”:{“D0”:1,“MS”:50}}
09:45:40 MQT: stat/sonoff11/RESULT = {“Event”:“Done”}
09:45:41 MQT: stat/sonoff11/RESULT = {“Event”:“Done”}
09:45:41 MQT: stat/sonoff11/RESULT = {“Time”:“2019-01-27T09:45:41”,“MCP230XX_INT”:{“D0”:1,“MS”:50}}
09:45:41 MQT: stat/sonoff11/RESULT = {“Time”:“2019-01-27T09:45:41”,“MCP230XX_INT”:{“D0”:1,“MS”:49}}
09:45:41 MQT: stat/sonoff11/RESULT = {“Time”:“2019-01-27T09:45:41”,“MCP230XX_INT”:{“D0”:1,“MS”:51}}
09:45:41 RSL: tele/sonoff11/STATE = {“Time”:“2019-01-27T09:45:41”,“Uptime”:“0T00:10:18”,“Vcc”:3.225,“SleepMode”:“Dynamic”,“Sleep”:50,“LoadAvg”:39,“POWER”:“OFF”,“Wifi”:{“AP”:1,“SSId”:“KevinWifi”,“BSSId”:“8C:3B:AD:30:88:F1”,“Channel”:9,“RSSI”:76}}
09:45:41 RSL: tele/sonoff11/SENSOR = {“Time”:“2019-01-27T09:45:41”,“Switch1”:“ON”,“BME280”:{“Temperature”:22.4,“Humidity”:43.7,“Pressure”:980.7},“BH1750”:{“Illuminance”:5},“MCP230XX”:{“D0”:1,“D1”:1,“D2”:1,“D3”:1,“D4”:1,“D5”:1,“D6”:1,“D7”:1,“D8”:1,“D9”:1,“D10”:1,“D11”:1,“D12”:1,“D13”:1,“D14”:1,“D15”:1},“PressureUnit”:“hPa”,“TempUnit”:“C”}
09:45:42 MQT: stat/sonoff11/RESULT = {“Time”:“2019-01-27T09:45:42”,“MCP230XX_INT”:{“D0”:1,“MS”:51}}
09:45:42 MQT: stat/sonoff11/RESULT = {“Event”:“Done”}
09:45:42 MQT: stat/sonoff11/RESULT = {“Time”:“2019-01-27T09:45:42”,“MCP230XX_INT”:{“D0”:1,“MS”:50}}
09:45:42 MQT: stat/sonoff11/RESULT = {“Time”:“2019-01-27T09:45:42”,“MCP230XX_INT”:{“D0”:1,“MS”:49}}
09:45:51 RSL: tele/sonoff11/STATE = {“Time”:“2019-01-27T09:45:51”,“Uptime”:“0T00:10:28”,“Vcc”:3.238,“SleepMode”:“Dynamic”,“Sleep”:50,“LoadAvg”:19,“POWER”:“OFF”,“Wifi”:{“AP”:1,“SSId”:“KevinWifi”,“BSSId”:“8C:3B:AD:30:88:F1”,“Channel”:9,“RSSI”:76}}
09:45:51 RSL: tele/sonoff11/SENSOR = {“Time”:“2019-01-27T09:45:51”,“Switch1”:“ON”,“BME280”:{“Temperature”:22.3,“Humidity”:43.1,“Pressure”:980.5},“BH1750”:{“Illuminance”:7},“MCP230XX”:{“D0”:0,“D1”:0,“D2”:0,“D3”:0,“D4”:0,“D5”:0,“D6”:0,“D7”:0,“D8”:0,“D9”:0,“D10”:0,“D11”:0,“D12”:0,“D13”:0,“D14”:0,“D15”:0},“PressureUnit”:“hPa”,“TempUnit”:“C”}
09:46:01 RSL: tele/sonoff11/STATE = {“Time”:“2019-01-27T09:46:01”,“Uptime”:“0T00:10:38”,“Vcc”:3.226,“SleepMode”:“Dynamic”,“Sleep”:50,“LoadAvg”:19,“POWER”:“OFF”,“Wifi”:{“AP”:1,“SSId”:“KevinWifi”,“BSSId”:“8C:3B:AD:30:88:F1”,“Channel”:9,“RSSI”:76}}
09:46:01 RSL: tele/sonoff11/SENSOR = {“Time”:“2019-01-27T09:46:01”,“Switch1”:“ON”,“BME280”:{“Temperature”:22.1,“Humidity”:43.0,“Pressure”:980.6},“BH1750”:{“Illuminance”:10},“MCP230XX”:{“D0”:0,“D1”:0,“D2”:0,“D3”:0,“D4”:0,“D5”:0,“D6”:0,“D7”:0,“D8”:0,“D9”:0,“D10”:0,“D11”:0,“D12”:0,“D13”:0,“D14”:0,“D15”:0},“PressureUnit”:“hPa”,“TempUnit”:“C”}
09:46:11 RSL: tele/sonoff11/STATE = {“Time”:“2019-01-27T09:46:11”,“Uptime”:“0T00:10:48”,“Vcc”:3.238,“SleepMode”:“Dynamic”,“Sleep”:50,“LoadAvg”:19,“POWER”:“OFF”,“Wifi”:{“AP”:1,“SSId”:“KevinWifi”,“BSSId”:“8C:3B:AD:30:88:F1”,“Channel”:9,“RSSI”:78}}
09:46:11 RSL: tele/sonoff11/SENSOR = {“Time”:“2019-01-27T09:46:11”,“Switch1”:“ON”,“BME280”:{“Temperature”:22.0,“Humidity”:43.0,“Pressure”:980.6},“BH1750”:{“Illuminance”:8},“MCP230XX”:{“D0”:0,“D1”:0,“D2”:0,“D3”:0,“D4”:0,“D5”:0,“D6”:0,“D7”:0,“D8”:0,“D9”:0,“D10”:0,“D11”:0,“D12”:0,“D13”:0,“D14”:0,“D15”:0},“PressureUnit”:“hPa”,“TempUnit”:“C”}
09:46:21 RSL: tele/sonoff11/STATE = {“Time”:“2019-01-27T09:46:21”,“Uptime”:“0T00:10:58”,“Vcc”:3.238,“SleepMode”:“Dynamic”,“Sleep”:50,“LoadAvg”:19,“POWER”:“OFF”,“Wifi”:{“AP”:1,“SSId”:“KevinWifi”,“BSSId”:“8C:3B:AD:30:88:F1”,“Channel”:9,“RSSI”:78}}
09:46:21 RSL: tele/sonoff11/SENSOR = {“Time”:“2019-01-27T09:46:21”,“Switch1”:“ON”,“BME280”:{“Temperature”:21.8,“Humidity”:43.4,“Pressure”:980.5},“BH1750”:{“Illuminance”:8},“MCP230XX”:{“D0”:0,“D1”:0,“D2”:0,“D3”:0,“D4”:0,“D5”:0,“D6”:0,“D7”:0,“D8”:0,“D9”:0,“D10”:0,“D11”:0,“D12”:0,“D13”:0,“D14”:0,“D15”:0},“PressureUnit”:“hPa”,“TempUnit”:“C”}
