Hello!
I have a Sonoff Basic R2 with a AM 312 motion sensor and my goal is to let the motion sensor turn on the switch for 5 minutes as long as there is motion detected,
So if motion is detetcted after 3 minutes, it should keep the switch on for another 5 minutes,
This is my current code:
esphome:
platform: ESP8266
board: esp01_1m
wifi:
ssid: !secret wifi_ssid
# Enable logging
logger:
# Enable Home Assistant API
api:
password: !secret http_password
ota:
binary_sensor:
- platform: gpio
pin: GPIO3
name: "PIR Sensor sbasic5"
device_class: motion
on_press:
then:
- switch.turn_on: relay
- delay: 300s
- swith.turn_off: relay
switch:
- platform: gpio
pin: GPIO12
status_led:
pin:
number: GPIO13
inverted: yes
It only works the first 5 minutes.
Do I need somehing like this?
# - platform: template
# lambda: 'return id(pirsbasic5).state;'
# filters:
# - delayed_off: 5min
# on_release:
# then:
# - switch.turn_off: relay
