Sonoff Basic with Motion and Tasmota
Have a MAME box with to many games
Want the Screen to come on when I walk up to it
shopping List
https://www.itead.cc/sonoff-wifi-wireless-switch.html
only needs 3.3v to run
Motion-Pin
red = 3.3v
yellow = GPI0 14
Black = GND
Flash the Sonoff with Tasmota 5.14
So I see the MQTT messages I setup GPI03 as a Relay2 (dummy one)
GPIO14 as Switch2
back to main screen
check the Log
log
looks good
now only problem is it send a ON them a OFF comand so I used nodered
The Nodered code
[{"id":"4695784b.b0ae88","type":"mqtt in","z":"d664133d.f572c","name":"MAME Motion","topic":"stat/MAME/POWER2","qos":"2","broker":"987c4047.b2d81","x":90,"y":360,"wires":[["aac420af.2c7df"]]},{"id":"69e6eee8.548e2","type":"debug","z":"d664133d.f572c","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":570,"y":420,"wires":[]},{"id":"9b992535.2929c8","type":"delay","z":"d664133d.f572c","name":"","pauseType":"delay","timeout":"2","timeoutUnits":"minutes","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"x":120,"y":480,"wires":[["792b35c4.6d4e7c"]]},{"id":"8c1ae8b0.fc9488","type":"mqtt out","z":"d664133d.f572c","name":"","topic":"nodered/motion2","qos":"","retain":"","broker":"987c4047.b2d81","x":590,"y":340,"wires":[]},{"id":"aac420af.2c7df","type":"function","z":"d664133d.f572c","name":"","func":"if (msg.payload ==\"ON\") {\n    msg.reset = true;\n    msg.payload = \"ON\"\n}\nelse{\n    \n    msg.payload = \"ON\"\n}\n\nreturn msg;","outputs":1,"noerr":0,"x":310,"y":320,"wires":[["8c1ae8b0.fc9488","69e6eee8.548e2","9b992535.2929c8"]]},{"id":"1becfca.4d5af03","type":"mqtt out","z":"d664133d.f572c","name":"","topic":"nodered/motion2","qos":"","retain":"","broker":"987c4047.b2d81","x":590,"y":520,"wires":[]},{"id":"792b35c4.6d4e7c","type":"function","z":"d664133d.f572c","name":"","func":"if (msg.payload ==\"ON\") {\n    msg.payload = \"OFF\"\n}\nelse{\n    msg.payload = \"OFF\"\n}\n\nreturn msg;","outputs":1,"noerr":0,"x":330,"y":460,"wires":[["1becfca.4d5af03","69e6eee8.548e2"]]},{"id":"987c4047.b2d81","type":"mqtt-broker","z":"","name":"","broker":"localhost","port":"1883","clientid":"","usetls":false,"compatmode":true,"keepalive":"60","cleansession":true,"birthTopic":"","birthQos":"0","birthPayload":"","willTopic":"","willQos":"0","willPayload":""}]
Now the HA automation
binarysensor
  - platform: mqtt
    state_topic: "nodered/motion2"
    qos: 2
    retain: true
    payload_on: "ON"
    payload_off: "OFF"
Switch
  - platform: mqtt
    entity_id: mamescreen
    state_topic: "stat/MAME/POWER1"
    command_topic: "cmnd/MAME/POWER1"
    payload_on: "ON"
    payload_off: "OFF"
    optimistic: false
    qos: 0
- id: '1530486159608'
  alias: Mame Screen ON
  - entity_id: binary_sensor.mame_motion
    platform: state
    to: 'on'
  condition: []
  - data:
      entity_id: switch.mame_screen
    service: switch.turn_on
- id: '1530486245034'
  alias: Mame Screen OFF
    platform: state
    to: 'off'
  condition: []
  - data:
    service: switch.turn_off
walk upto MAME box and the Screen comes on stay on until I walk away after about 2mins ±
hope this help someone
Cool project! When I use the dummy relay, GPIO 4 usually works well since it isn’t hooked up at all on the chip, keeps the serial pins open in case you need to tag into those for some reason for troubleshooting later.
cool project. thanks for sharing!
Hi, could you please explain to me better how you did the programming part. thank you
AS motion sensor Send a ON then a OFF HA would just see a ON then OFF
So I use Nodered to look at the stats/MAME/POWER2 if it get a ON it send the ON to the nodered/motion2 and put a delay OFF for 2m and then send the OFF to nodered/motion2 then if it get a only ON ( I MOVED) it just send the ON again and reset the delay. waits for and other 2m
HA DOES NOT KNOW ABOUT “stats/MAME/POWER2” only nodered/motion2
if you have node red install just paste this
into node red
He
1st has this in it
2nd has this
Dont understand how it works but got it to work
then use automation to turn on/off the screen
hope this make cents
When I saw this I got very excited and and decided to do this in every room I have Sonoff in, but I couldn’t get past the first step.
When I connect the pir sensor to the board it fails to connect to wifi and restarts every few seconds. When I take the sensor off every thing goes back to normal.
I’ve tried to flip the wires just in case I was mistaken but it didn’t help.
These are the pir sensors I’m using.
https://s.click.aliexpress.com/e/cb9qed8y
What pin did u attach it to and what verson of sonoff was it
Sonoff basic running Tasmota. At first I tried +, GND, GPIO 14 then every possible option. Still nothing
Did u try just using a wire from gpio14 to ground that will tell us if it’s the pir playing up
I’ve tried using another sonoff device and now it works like a charm.
What’s the best way to add this as a binary sensor to HA? Should I create a template sensor?
I don’t use node red
Many thanks
As the pir send a on then a off that why I used node red to control the off send but if u can work out a way to keep it all in HA that make me a happy camper also
