Hi all,
I have the sonoff rf bridge flashed with the tasmota software. I am using it to control plugs that came with a remote. To control the plugs i copied the code that the remote sends and made a switch out of that in homeassistant. This all works great and I loved it… until I got more plugs in the same room. When I turned them on/off, only 1 responded of the 2. Apparently the bridge can’t send codes in a short time apard from each other. This is no problem until you use voice commands like ‘hey google, turn bedroom on’, this will turn both switches on simontaneously causing 1 to fail.
Has anyone got a solution for this? The problem only seems to exist with my ‘KAKU’ or ‘Klik Aan Klik Uit’ systems.
Here is an example of the RF codes they use:
backlog rfraw AA B0 4E 05 08 0136 0A32 00DC 04D8 27BA 481828382838380838082838283838082838380828383808380838080838380838083808380808380838380828383808083838080838083838082838083808380838 55
And here is one where there is no problem:
backlog rfraw AAB0230408012204C401D6092E0112121212010101121201121212120101121201121201010355
