I noticed every once in a while I lose connection to sonoff bridge with tasmota. Someone knows if there is a way to monitor the bridge from hassio to see if it’s offline?
The broker should send out the LWT message to anything subscribed if the sonoff disconnects unexpectedly. Which broker are you using?
Hello. Mosquito broker
That should work fine.
Does the sonoff send a LWT message to the broker when it starts?
You may look at this thread for ideas
Thank you. I’ll check it out.
