I’m using z2m with Home Assistant and I have several devices in my network.
Recently, I successfully paired a new Sonoff button (model SNZB-01) that connected to a router (an Aqara outlet, model SP-EUC01).
I noticed that every time I press the Sonoff button it toggles the Aqara outlet on and off.
Is there any way I can prevent the Sonoff button from controlling the Aqara outlet?
Below is a screen grab from my z2m map, including the Sonoff Button, the Aqara outlet and the coordinator.
Following up on this, I finally managed to repair it AND have it not bound to the Aqara outlet. Sharing the steps I followed with the community, should anyone run in to the same issues I did:
Physically removed the outlet from mains - as in had it on my desk, unplugged.
Force removed the Sonoff Button from z2m.
Restarted z2m from Home Assistant Settings, Add-ons, z2m (oddly enough only this helped repairing the button and it properly reporting back all it’s available settings - in previous attempts I had restarted the entire Home Assistant server instead of only the z2m add-on)
Back in z2m, hit permit join (Coordinator only)
Reset the Sonoff Button by pressing the reset button for 5 seconds until the red led flashes.
The Sonoff Button pairs successfully, interviews successfully and gets configured successfully (this step was missing from the logs when I was restarting the entire Home Assistant server instead of only restarting the z2m add-on) before repairing.
Plugged the Aqara outlet back into mains.
This seems to do the trick. One weird thing that I noticed, was that although I had Permit Join (Coordinator) only enabled, the button got bound to another router on the network instead of directly to the Coordinator as I would’ve expected it.
I hope in time the button won’t get rerouted through the outlet again, since the outlet is physically closest to it.
