Hi All – I received 5 Sonoff D1 Wifi dimmers through the post, however I find it impossible to: i. make eWeLink app to see any of them –despite following the manual and on-screen directions to the letter, ii. flicked the switch to OTA, but still serial port is closed, iii. checked if there is a WiFi hotspot from the device for me to connect.
So far – ALL unsuccessful. Any idea what’s going on?
Re: the pairing process with eWeLink, the issue was that my phone joined the WiFi network at 5G whereas the Dimmer only supports 2.4G. Once I deactivated the 5G radio on my UniFi, the pairing was flawless.
I had success using compatible pairing mode, but i did have issues at first.
i had to open up the d1 dimmer and watch the led light whilst turning it on and off after a second for five times to reset the d1 dimmer. Once the led stayed solid i used compatible pairing mode on Ewelink App (android).
I have not had any luck getting the D1 imported in to Home Assistant via the unofficial add on i get an error saying the following…
Can’t get it to work. Have 3 Sonoff relays in DIY mode, these are ok, and two old relays in Local mode. But D1 refusing to work. Can’t even enter ewelink credentials - “sign verification failed” every time i try. They are correct, though - i can log in into ewelink app on tabllet. AlexxIT component at last version, 3.0.5.
