I’m playing with D1 dimmer in my ESPhome. I’ve pretty much all figured it out, except dimming down. I use “relative_brightness” for dimming, and dimm up works fine. BUT… if i dimm down, when it comes to zero light kinda flashes, then it turns off. First, i don’t want that flash, but more important: i’d like to dimm down to 1%, not to zero (which turns light off).
How to read and take into account current brightness status? I guess i need some kind of lambda function to implement into “IF” sentence.
Any help very appreciated…
My current working principle:
- short push: if OFF, light goes to 100%, if ON goes OFF.
- long push: if OFF, light goes to 1%, if ON goes into dimming. Release and long re-press reverses direction.
I use global variable “dimanje” for dimm direction.
my current code:
substitutions:
devicename: d1_dimmer
friendly_name: Dimmer
esphome:
platform: ESP8266
board: esp01_1m
# Include our custom code
includes:
- d1_dimmer_no_rf.h
globals:
- id: dimanje
type: bool
initial_value: 'true'
wifi:
ssid: !secret wifi_ssid
#use_address: power.local
manual_ip:
static_ip: 192.168.0.95
gateway: 192.168.0.1
subnet: 255.255.255.0
ap:
ssid: "Power Fallback Hotspot"
password: !secret ota_password
ap_timeout: 5min
captive_portal:
# Enable logging
logger:
# Enable Home Assistant API
api:
ota:
# TODO: Set these as your own web server credentials
web_server:
port: 80
# Uses the onboard LED as status indicator
status_led:
pin:
number: GPIO13
inverted: True
# Report basic device information like it's Wi-Fi signal strength and uptime
- platform: wifi_signal
name: ${friendly_name} WiFi Signal
update_interval: 60s
- platform: uptime
filters:
- lambda: return x / 60.0;
unit_of_measurement: minutes
# Basic switch to allow you to restart the device remotely
switch:
- platform: restart
binary_sensor:
- platform: status
name: "Sonoff D1 Status"
- platform: gpio
internal: true
pin:
number: GPIO4
mode: INPUT_PULLUP
inverted: true
on_multi_click:
- timing:
- ON for at most 0.5s
then:
if:
condition:
light.is_on: main
then:
- light.turn_off:
else:
- light.turn_on:
brightness: 100%
#označim, da je naslednja faza dim DOL
- lambda: |-
id(dimanje) = (false);
- timing:
- ON for at least 0.51s
then:
#če je izključena, vklopim na 1%
if:
condition:
light.is_off: main
then:
- light.turn_on:
brightness: 1%
#sicer dimmam
else:
- if:
condition:
lambda: |-
ESP_LOGD("Stanje", "Boolean: %d", id(dimanje));
return id(dimanje);
then:
- while:
condition:
binary_sensor.is_on: tipka
then:
- light.dim_relative:
relative_brightness: 10%
transition_length: 0.5s
- delay: 0.5s
- lambda: |-
else:
- while:
condition:
then:
relative_brightness: -20%
- delay: 0.5s
- lambda: |-
id(dimanje) = (true);
# Define our custom light component
light:
- platform: custom
lambda: |-
auto dimmer_light = new Sonoff_D1_Dimmer();
App.register_component(dimmer_light);
return {dimmer_light};
lights:
- name: $friendly_name
default_transition_length: 100 ms
restore_mode: RESTORE_DEFAULT_OFF
gamma_correct: 0
