Full diagnostics
"home_assistant": {
"installation_type": "Home Assistant Container",
"version": "2022.11.1",
"dev": false,
"hassio": false,
"virtualenv": false,
"python_version": "3.10.7",
"docker": true,
"arch": "x86_64",
"timezone": "Asia/Kuala_Lumpur",
"os_name": "Linux",
"os_version": "4.4.59+",
"run_as_root": true
"custom_components": {
"bemfa": {
"version": "1.0.0",
"requirements": [
"paho-mqtt==1.6.1"
"xiaomi_miot_raw": {
"version": "v1.3.1",
"requirements": [
"construct",
"python-miio>=0.5.3"
"smartthinq_sensors": {
"version": "0.24.2",
"requirements": [
"pycountry>=20.7.3",
"xmltodict>=0.12.0",
"cchardet>=2.1.7"
"nodered": {
"version": "1.1.2",
"requirements": []
"browser_mod": {
"version": "2.1.2",
"requirements": []
"edge_tts": {
"version": "0.0.1",
"requirements": [
"edge-tts==5.0.6"
"xiaomi_miot": {
"version": "0.7.0",
"requirements": [
"construct==2.10.56",
"python-miio>=0.5.6",
"micloud>=0.3"
"hacs": {
"version": "1.28.3",
"requirements": [
"aiogithubapi>=22.2.4"
"config_editor": {
"version": "4.3",
"requirements": []
"sonoff": {
"version": "3.3.1",
"requirements": [
"pycryptodome>=3.6.6"
"integration_manifest": {
"domain": "sonoff",
"name": "Sonoff",
"config_flow": true,
"documentation": "https://github.com/AlexxIT/SonoffLAN",
"issue_tracker": "/api/sonoff/da11df70-9c59-427e-8344-bb6af3913fb7",
"codeowners": [
"@AlexxIT"
"dependencies": [
"http",
"zeroconf"
"requirements": [
"version": "3.3.1",
"iot_class": "local_push",
"is_built_in": false
"data": {
"version": "b20e33c",
"cloud_auth": true,
"config": null,
"options": {
"mode": "auto",
"debug": true
"errors": [
"name": "custom_components.sonoff.core.ewelink.cloud",
"message": [
"Cloud WS Connection error: Cannot connect to host as-pconnect6.coolkit.cc:8080 ssl:default [None]",
"Cloud WS Connection error: Cannot connect to host as-pconnect4.coolkit.cc:8080 ssl:default [None]",
"Cloud WS Connection error: Cannot connect to host as-pconnect2.coolkit.cc:8080 ssl:default [None]",
"Cloud WS Connection error: Cannot connect to host as-pconnect5.coolkit.cc:8080 ssl:default [None]",
"Cloud WS Connection error: Cannot connect to host as-pconnect3.coolkit.cc:8080 ssl:default [None]"
"level": "WARNING",
"source": [
"custom_components/sonoff/core/ewelink/cloud.py",
268
"timestamp": 1667923336.179008,
"exception": "",
"count": 12,
"first_occurred": 1667904020.3973825
"devices": {
"10017f65b9": {
"uiid": 2,
"params": {
"bindInfos": "***",
"version": 8,
"only_device": {
"ota": "success"
"sledOnline": "on",
"ssid": "***",
"bssid": "***",
"fwVersion": "3.5.1",
"staMac": "***",
"rssi": -36,
"init": 1,
"lock": 0,
"configure": [
"startup": "off",
"outlet": 0
"startup": "off",
"outlet": 1
"startup": "off",
"outlet": 2
"startup": "off",
"outlet": 3
"pulses": [
"pulse": "off",
"width": 1000,
"outlet": 0
"pulse": "off",
"width": 1000,
"outlet": 1
"pulse": "off",
"width": 1000,
"outlet": 2
"pulse": "off",
"width": 1000,
"outlet": 3
"switches": [
"switch": "off",
"outlet": 0
"switch": "off",
"outlet": 1
"switch": "off",
"outlet": 2
"switch": "off",
"outlet": 3
"model": "0285",
"online": true,
"localtype": null
"10017f701b": {
"uiid": 3,
"params": {
"bindInfos": "***",
"version": 8,
"only_device": {
"ota": "success"
"sledOnline": "on",
"ssid": "***",
"bssid": "***",
"staMac": "***",
"rssi": -65,
"init": 1,
"lock": 0,
"configure": [
"startup": "off",
"outlet": 0
"startup": "off",
"outlet": 1
"startup": "off",
"outlet": 2
"startup": "off",
"outlet": 3
"pulses": [
"pulse": "off",
"width": 1000,
"outlet": 0
"pulse": "off",
"width": 1000,
"outlet": 1
"pulse": "off",
"width": 1000,
"outlet": 2
"pulse": "off",
"width": 1000,
"outlet": 3
"switches": [
"switch": "off",
"outlet": 0
"switch": "off",
"outlet": 1
"switch": "off",
"outlet": 2
"switch": "off",
"outlet": 3
"model": "0385",
"online": true,
"localtype": null
"10017f609c": {
"uiid": 1,
"params": {
"bindInfos": "***",
"version": 8,
"only_device": {
"ota": "success"
"sledOnline": "on",
"ssid": "***",
"bssid": "***",
"switch": "off",
"rssi": -72,
"staMac": "***",
"startup": "off",
"init": 1,
"pulse": "off",
"pulseWidth": 500
"model": "0185",
"online": true,
"localtype": null
"10017f6802": {
"uiid": 2,
"params": {
"bindInfos": "***",
"version": 8,
"only_device": {
"ota": "success"
"sledOnline": "on",
"ssid": "***",
"bssid": "***",
"staMac": "***",
"rssi": -50,
"init": 1,
"lock": 0,
"configure": [
"startup": "off",
"outlet": 0
"startup": "off",
"outlet": 1
"startup": "off",
"outlet": 2
"startup": "off",
"outlet": 3
"pulses": [
"pulse": "off",
"width": 1000,
"outlet": 0
"pulse": "off",
"width": 1000,
"outlet": 1
"pulse": "off",
"width": 1000,
"outlet": 2
"pulse": "off",
"width": 1000,
"outlet": 3
"switches": [
"switch": "off",
"outlet": 0
"switch": "off",
"outlet": 1
"switch": "off",
"outlet": 2
"switch": "off",
"outlet": 3
"model": "0285",
"online": true,
"localtype": null
"10017f6a42": {
"uiid": 3,
"params": {
"bindInfos": "***",
"version": 8,
"only_device": {
"ota": "success"
"sledOnline": "on",
"ssid": "***",
"bssid": "***",
"staMac": "***",
"rssi": -44,
"init": 1,
"lock": 0,
"configure": [
"startup": "off",
"outlet": 0
"startup": "off",
"outlet": 1
"startup": "off",
"outlet": 2
"startup": "off",
"outlet": 3
"pulses": [
"pulse": "off",
"width": 1000,
"outlet": 0
"pulse": "off",
"width": 1000,
"outlet": 1
"pulse": "off",
"width": 1000,
"outlet": 2
"pulse": "off",
"width": 1000,
"outlet": 3
"switches": [
"switch": "off",
"outlet": 0
"switch": "off",
"outlet": 1
"switch": "off",
"outlet": 2
"switch": "off",
"outlet": 3
"model": "0385",
"online": true,
"localtype": null
"10017f67be": {
"uiid": 2,
"params": {
"bindInfos": "***",
"version": 8,
"only_device": {
"ota": "success"
"sledOnline": "on",
"ssid": "***",
"bssid": "***",
"staMac": "***",
"rssi": -40,
"init": 1,
"lock": 0,
"configure": [
"startup": "off",
"outlet": 0
"startup": "off",
"outlet": 1
"startup": "off",
"outlet": 2
"startup": "off",
"outlet": 3
"pulses": [
"pulse": "off",
"width": 1000,
"outlet": 0
"pulse": "off",
"width": 1000,
"outlet": 1
"pulse": "off",
"width": 1000,
"outlet": 2
"pulse": "off",
"width": 1000,
"outlet": 3
"switches": [
"switch": "off",
"outlet": 0
"switch": "off",
"outlet": 1
"switch": "off",
"outlet": 2
"switch": "off",
"outlet": 3
"model": "0285",
"online": true,
"localtype": null
"10017f61df": {
"uiid": 2,
"params": {
"bindInfos": "***",
"version": 8,
"only_device": {
"ota": "success"
"sledOnline": "on",
"ssid": "***",
"bssid": "***",
"staMac": "***",
"rssi": -43,
"init": 1,
"lock": 0,
"configure": [
"startup": "off",
"outlet": 0
"startup": "off",
"outlet": 1
"startup": "off",
"outlet": 2
"startup": "off",
"outlet": 3
"pulses": [
"pulse": "off",
"width": 1000,
"outlet": 0
"pulse": "off",
"width": 1000,
"outlet": 1
"pulse": "off",
"width": 1000,
"outlet": 2
"pulse": "off",
"width": 1000,
"outlet": 3
"switches": [
"switch": "off",
"outlet": 0
"switch": "off",
"outlet": 1
"switch": "off",
"outlet": 2
"switch": "off",
"outlet": 3
"model": "0285",
"online": true,
"localtype": null
"10017f5cbb": {
"uiid": 1,
"params": {
"bindInfos": "***",
"version": 8,
"only_device": {
"ota": "success"
"sledOnline": "on",
"ssid": "***",
"bssid": "***",
"switch": "off",
"rssi": -61,
"staMac": "***",
"startup": "off",
"init": 1,
"pulse": "off",
"pulseWidth": 500
"model": "0185",
"online": true,
"localtype": null
"10017f5ac7": {
"uiid": 1,
"params": {
"bindInfos": "***",
"version": 8,
"only_device": {
"ota": "success"
"sledOnline": "on",
"ssid": "***",
"bssid": "***",
"switch": "off",
"rssi": -63,
"staMac": "***",
"startup": "off",
"init": 1,
"pulse": "off",
"pulseWidth": 500
"model": "0185",
"online": true,
"localtype": null
"10017f6602": {
"uiid": 2,
"params": {
"bindInfos": "***",
"version": 8,
"only_device": {
"ota": "success"
"sledOnline": "on",
"ssid": "***",
"bssid": "***",
"staMac": "***",
"rssi": -27,
"init": 1,
"lock": 0,
"configure": [
"startup": "off",
"outlet": 0
"startup": "off",
"outlet": 1
"startup": "off",
"outlet": 2
"startup": "off",
"outlet": 3
"pulses": [
"pulse": "off",
"width": 1000,
"outlet": 0
"pulse": "off",
"width": 1000,
"outlet": 1
"pulse": "off",
"width": 1000,
"outlet": 2
"pulse": "off",
"width": 1000,
"outlet": 3
"switches": [
"switch": "off",
"outlet": 0
"switch": "off",
"outlet": 1
"switch": "off",
"outlet": 2
"switch": "off",
"outlet": 3
"model": "0285",
"online": true,
"localtype": null
"10017f6801": {
"uiid": 2,
"params": {
"bindInfos": "***",
"version": 8,
"only_device": {
"ota": "success"
"sledOnline": "on",
"ssid": "***",
"bssid": "***",
"staMac": "***",
"rssi": -31,
"init": 1,
"lock": 0,
"configure": [
"startup": "off",
"outlet": 0
"startup": "off",
"outlet": 1
"startup": "off",
"outlet": 2
"startup": "off",
"outlet": 3
"pulses": [
"pulse": "off",
"width": 1000,
"outlet": 0
"pulse": "off",
"width": 1000,
"outlet": 1
"pulse": "off",
"width": 1000,
"outlet": 2
"pulse": "off",
"width": 1000,
"outlet": 3
"switches": [
"switch": "off",
"outlet": 0
"switch": "off",
"outlet": 1
"switch": "off",
"outlet": 2
"switch": "off",
"outlet": 3
"model": "0285",
"online": true,
"localtype": null
"10017f6a48": {
"uiid": 3,
"params": {
"bindInfos": "***",
"version": 8,
"only_device": {
"ota": "success"
"sledOnline": "on",
"ssid": "***",
"bssid": "***",
"staMac": "***",
"rssi": -29,
"init": 1,
"lock": 0,
"configure": [
"startup": "off",
"outlet": 0
"startup": "off",
"outlet": 1
"startup": "off",
"outlet": 2
"startup": "off",
"outlet": 3
"pulses": [
"pulse": "off",
"width": 1000,
"outlet": 0
"pulse": "off",
"width": 1000,
"outlet": 1
"pulse": "off",
"width": 1000,
"outlet": 2
"pulse": "off",
"width": 1000,
"outlet": 3
"switches": [
"switch": "off",
"outlet": 0
"switch": "off",
"outlet": 1
"switch": "off",
"outlet": 2
"switch": "off",
"outlet": 3
"model": "0385",
"online": true,
"localtype": null
"10017f6a7f": {
"uiid": 3,
"params": {
"bindInfos": "***",
"version": 8,
"only_device": {
"ota": "success"
"sledOnline": "on",
"ssid": "***",
"bssid": "***",
"staMac": "***",
"rssi": -32,
"init": 1,
"lock": 0,
"configure": [
"startup": "off",
"outlet": 0
"startup": "off",
"outlet": 1
"startup": "off",
"outlet": 2
"startup": "off",
"outlet": 3
"pulses": [
"pulse": "off",
"width": 1000,
"outlet": 0
"pulse": "off",
"width": 1000,
"outlet": 1
"pulse": "off",
"width": 1000,
"outlet": 2
"pulse": "off",
"width": 1000,
"outlet": 3
"switches": [
"switch": "off",
"outlet": 0
"switch": "off",
"outlet": 1
"switch": "off",
"outlet": 2
"switch": "off",
"outlet": 3
"model": "0385",
"online": true,
"localtype": null
"1000b947ee": {
"uiid": 1,
"params": {
"bindInfos": "***",
"version": 8,
"sledOnline": "on",
"switch": "off",
"fwVersion": "3.6.0",
"rssi": -34,
"staMac": "***",
"startup": "off",
"init": 1,
"pulse": "off",
"pulseWidth": 500,
"swMode": 2,
"swCtrlReverse": "off"
"model": "BASICRF_R3",
"online": true,
"localtype": null
"1000ed8282": {
"uiid": 1,
"params": {
"bindInfos": "***",
"version": 8,
"sledOnline": "on",
"switch": "off",
"rssi": -56,
"staMac": "***",
"startup": "off",
"init": 1,
"pulse": "off",
"pulseWidth": 500,
"swMode": 2,
"online": true,
"localtype": null
"1000c7e935": {
"uiid": 1,
"params": {
"bindInfos": "***",
"version": 8,
"sledOnline": "on",
"switch": "off",
"rssi": -59,
"staMac": "***",
"startup": "off",
"init": 1,
"pulse": "off",
"pulseWidth": 500,
"swMode": 2,
"online": true,
"localtype": null
"1001092eb1": {
"uiid": 4,
"params": {
"bindInfos": "***",
"version": 8,
"sledOnline": "on",
"staMac": "***",
"rssi": -70,
"init": 1,
"lock": 0,
"configure": [
"startup": "off",
"outlet": 0
"startup": "off",
"outlet": 1
"startup": "off",
"outlet": 2
"startup": "off",
"outlet": 3
"pulses": [
"pulse": "on",
"width": 500,
"outlet": 0
"pulse": "on",
"width": 500,
"outlet": 1
"pulse": "on",
"width": 500,
"outlet": 2
"pulse": "on",
"width": 500,
"outlet": 3
"switches": [
"switch": "off",
"outlet": 0
"switch": "off",
"outlet": 1
"switch": "off",
"outlet": 2
"switch": "off",
"outlet": 3
"zyx_clear_timers": false,
"only_device": {
"ota": "success"
"ssid": "***",
"bssid": "***"
"model": "0485",
"online": true,
"localtype": null
"1001092921": {
"uiid": 4,
"params": {
"bindInfos": "***",
"version": 8,
"sledOnline": "on",
"staMac": "***",
"rssi": -82,
"init": 1,
"lock": 0,
"configure": [
"startup": "off",
"outlet": 0
"startup": "off",
"outlet": 1
"startup": "off",
"outlet": 2
"startup": "off",
"outlet": 3
"pulses": [
"pulse": "on",
"width": 500,
"outlet": 0
"pulse": "on",
"width": 500,
"outlet": 1
"pulse": "on",
"width": 500,
"outlet": 2
"pulse": "on",
"width": 500,
"outlet": 3
"switches": [
"switch": "off",
"outlet": 0
"switch": "off",
"outlet": 1
"switch": "off",
"outlet": 2
"switch": "off",
"outlet": 3
"only_device": {
"ota": "success"
"ssid": "***",
"bssid": "***"
"model": "0485",
"online": true,
"localtype": null
"1001092ea1": {
"uiid": 4,
"params": {
"bindInfos": "***",
"version": 8,
"sledOnline": "on",
"staMac": "***",
"rssi": -75,
"init": 1,
"lock": 0,
"configure": [
"startup": "off",
"outlet": 0
"startup": "off",
"outlet": 1
"startup": "off",
"outlet": 2
"startup": "off",
"outlet": 3
"pulses": [
"pulse": "on",
"width": 500,
"outlet": 0
"pulse": "on",
"width": 500,
"outlet": 1
"pulse": "on",
"width": 500,
"outlet": 2
"pulse": "on",
"width": 500,
"outlet": 3
"switches": [
"switch": "off",
"outlet": 0
"switch": "off",
"outlet": 1
"switch": "off",
"outlet": 2
"switch": "off",
"outlet": 3
"only_device": {
"ota": "success"
"ssid": "***",
"bssid": "***"
"model": "0485",
"online": true,
"localtype": null
"1000f21421": {
"uiid": 28,
"params": {
"bindInfos": "***",
"version": 8,
"sledOnline": "on",
"ssid": "***",
"bssid": "***",
"init": 1,
"fwVersion": "3.5.0",
"rssi": -69,
"staMac": "***",
"setState": "arm",
"rfList": [],
"cmd": "edit",
"rfTrig0": 0,
"timers": "***",
"rfTrig2": 0
"model": "RFBridge433",
"online": false,
"localtype": null
"10010987bf": {
"uiid": 102,
"params": {
"bindInfos": "***",
"switch": "off",
"battery": 2.206,
"fwVersion": "1000.2.925",
"type": 4,
"chipID": "d02702130cce",
"mac": "***",
"rssi": -77,
"lastUpdateTime": "2021-06-29T03:24:11.496Z",
"actionTime": "2021-06-17T09:46:30.771Z"
"model": "DW2-Wi-Fi",
"online": false,
"localtype": null
