Hi All – I managed to flash a Dimmer D1 w/ Tasmota successfully, however I have the following issue. It powers on rather randomly, not even being recognised as ON within Home Assistant.
From the logs, I managed to get this:
ESP-DMP: AA 55 01 04 00 00 05
ESP-CFG: Saved to flash at F4, Count 80, Bytes 4096
ESP-MQT: stat/tasmota_DB2C7B/RESULT = {“POWER”:“ON”,“Dimmer”:100}
ESP-SRC: Light
ESP-CMD: Group 0, Index 1, Command “DIMMER”, Data “100”
ESP-SRC: MQTT
ESP-MQT: Received Topic “cmnd/tasmota_DB2C7B/dimmer”, Data Size 3, Data “100”
ESP-MQT: stat/tasmota_DB2C7B/POWER = OFF
ESP-MQT: stat/tasmota_DB2C7B/RESULT = {“POWER”:“OFF”}
ESP-CMD: Group 0, Index 1, Command “POWER”, Data “OFF”
ESP-SRC: MQTT
ESP-MQT: Received Topic “cmnd/tasmota_DB2C7B/power”, Data Size 3, Data “OFF”
ESP-MQT: Subscribe to cmnd/DVES_DB2C7B_fb/#
ESP-MQT: Subscribe to cmnd/tasmotas/#
ESP-MQT: Subscribe to cmnd/tasmota_DB2C7B/#
ESP-MQT: cmnd/tasmota_DB2C7B/POWER =
ESP-MQT: tele/tasmota_DB2C7B/LWT = Online (retained)
Is this helpful? What can it be done to fix this?
