Ronhoo
(Ronald)
December 2, 2024, 10:02pm
1
Recently I have been getting error messages with my Sonoff E dongle. With the latest firmware
I think all settings are correct. Who can help me with this?
Starting Zigbee2MQTT without watchdog.
[2024-12-02 22:56:14] info: z2m: Logging to console, file (filename: log.log)
[2024-12-02 22:56:14] info: z2m: Starting Zigbee2MQTT version 1.42.0 (commit #unknown)
[2024-12-02 22:56:14] info: z2m: Starting zigbee-herdsman (2.1.9)
[2024-12-02 22:56:14] info: zh:ember: Using default stack config.
[2024-12-02 22:56:14] info: zh:ember: ======== Ember Adapter Starting ========
[2024-12-02 22:56:14] info: zh:ember:ezsp: ======== EZSP starting ========
[2024-12-02 22:56:14] info: zh:ember:uart:ash: ======== ASH Adapter reset ========
[2024-12-02 22:56:14] info: zh:ember:uart:ash: RTS/CTS config is off, enabling software flow control.
[2024-12-02 22:56:14] info: zh:ember:uart:ash: ASH COUNTERS since last clear:
[2024-12-02 22:56:14] info: zh:ember:uart:ash: Total frames: RX=0, TX=0
[2024-12-02 22:56:14] info: zh:ember:uart:ash: Cancelled : RX=0, TX=0
[2024-12-02 22:56:14] info: zh:ember:uart:ash: DATA frames : RX=0, TX=0
[2024-12-02 22:56:14] info: zh:ember:uart:ash: DATA bytes : RX=0, TX=0
[2024-12-02 22:56:14] info: zh:ember:uart:ash: Retry frames: RX=0, TX=0
[2024-12-02 22:56:14] info: zh:ember:uart:ash: ACK frames : RX=0, TX=0
[2024-12-02 22:56:14] info: zh:ember:uart:ash: NAK frames : RX=0, TX=0
[2024-12-02 22:56:14] info: zh:ember:uart:ash: nRdy frames : RX=0, TX=0
[2024-12-02 22:56:14] info: zh:ember:uart:ash: CRC errors : RX=0
[2024-12-02 22:56:14] info: zh:ember:uart:ash: Comm errors : RX=0
[2024-12-02 22:56:14] info: zh:ember:uart:ash: Length < minimum: RX=0
[2024-12-02 22:56:14] info: zh:ember:uart:ash: Length > maximum: RX=0
[2024-12-02 22:56:14] info: zh:ember:uart:ash: Bad controls : RX=0
[2024-12-02 22:56:14] info: zh:ember:uart:ash: Bad lengths : RX=0
[2024-12-02 22:56:14] info: zh:ember:uart:ash: Bad ACK numbers : RX=0
[2024-12-02 22:56:14] info: zh:ember:uart:ash: Out of buffers : RX=0
[2024-12-02 22:56:14] info: zh:ember:uart:ash: Retry dupes : RX=0
[2024-12-02 22:56:14] info: zh:ember:uart:ash: Out of sequence : RX=0
[2024-12-02 22:56:14] info: zh:ember:uart:ash: ACK timeouts : RX=0
[2024-12-02 22:56:14] info: zh:ember:uart:ash: ======== ASH stopped ========
[2024-12-02 22:56:14] error: zh:ember:uart:ash: Failed to init port with error Error: Error Resource temporarily unavailable Cannot lock port
[2024-12-02 22:56:14] error: z2m: Error while starting zigbee-herdsman
[2024-12-02 22:56:14] error: z2m: Failed to start zigbee
[2024-12-02 22:56:14] error: z2m: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start.html for possible solutions
[2024-12-02 22:56:14] error: z2m: Exiting...
[2024-12-02 22:56:14] error: z2m: Error: Failed to start EZSP layer with status=HOST_FATAL_ERROR.
at EmberAdapter.initEzsp (/app/node_modules/zigbee-herdsman/src/adapter/ember/adapter/emberAdapter.ts:684:19)
at EmberAdapter.start (/app/node_modules/zigbee-herdsman/src/adapter/ember/adapter/emberAdapter.ts:1598:24)
at Controller.start (/app/node_modules/zigbee-herdsman/src/controller/controller.ts:137:29)
at Zigbee.start (/app/lib/zigbee.ts:69:27)
at Controller.start (/app/lib/controller.ts:161:27)
at start (/app/index.js:154:5)
I have the same problem. After update at 14.0
[12:10:53] INFO: Preparing to start...
[12:10:53] INFO: Socat not enabled
[12:10:53] INFO: Starting Zigbee2MQTT...
[2024-12-08 12:10:59] info: z2m: Logging to console, file (filename: log.log)
[2024-12-08 12:10:59] info: z2m: Starting Zigbee2MQTT version 1.42.0 (commit #unknown)
[2024-12-08 12:10:59] info: z2m: Starting zigbee-herdsman (2.1.9)
[2024-12-08 12:10:59] info: zh:ember: Using default stack config.
[2024-12-08 12:10:59] info: zh:ember: ======== Ember Adapter Starting ========
[2024-12-08 12:10:59] info: zh:ember:ezsp: ======== EZSP starting ========
[2024-12-08 12:10:59] info: zh:ember:uart:ash: ======== ASH Adapter reset ========
[2024-12-08 12:10:59] info: zh:ember:uart:ash: RTS/CTS config is off, enabling software flow control.
[2024-12-08 12:10:59] info: zh:ember:uart:ash: ASH COUNTERS since last clear:
[2024-12-08 12:10:59] info: zh:ember:uart:ash: Total frames: RX=0, TX=0
[2024-12-08 12:10:59] info: zh:ember:uart:ash: Cancelled : RX=0, TX=0
[2024-12-08 12:10:59] info: zh:ember:uart:ash: DATA frames : RX=0, TX=0
[2024-12-08 12:10:59] info: zh:ember:uart:ash: DATA bytes : RX=0, TX=0
[2024-12-08 12:10:59] info: zh:ember:uart:ash: Retry frames: RX=0, TX=0
[2024-12-08 12:10:59] info: zh:ember:uart:ash: ACK frames : RX=0, TX=0
[2024-12-08 12:10:59] info: zh:ember:uart:ash: NAK frames : RX=0, TX=0
[2024-12-08 12:10:59] info: zh:ember:uart:ash: nRdy frames : RX=0, TX=0
[2024-12-08 12:10:59] info: zh:ember:uart:ash: CRC errors : RX=0
[2024-12-08 12:10:59] info: zh:ember:uart:ash: Comm errors : RX=0
[2024-12-08 12:10:59] info: zh:ember:uart:ash: Length < minimum: RX=0
[2024-12-08 12:10:59] info: zh:ember:uart:ash: Length > maximum: RX=0
[2024-12-08 12:10:59] info: zh:ember:uart:ash: Bad controls : RX=0
[2024-12-08 12:10:59] info: zh:ember:uart:ash: Bad lengths : RX=0
[2024-12-08 12:10:59] info: zh:ember:uart:ash: Bad ACK numbers : RX=0
[2024-12-08 12:10:59] info: zh:ember:uart:ash: Out of buffers : RX=0
[2024-12-08 12:10:59] info: zh:ember:uart:ash: Retry dupes : RX=0
[2024-12-08 12:10:59] info: zh:ember:uart:ash: Out of sequence : RX=0
[2024-12-08 12:10:59] info: zh:ember:uart:ash: ACK timeouts : RX=0
[2024-12-08 12:10:59] info: zh:ember:uart:ash: ======== ASH stopped ========
[2024-12-08 12:10:59] error: zh:ember:uart:ash: Failed to init port with error Error: Error Resource temporarily unavailable Cannot lock port
[2024-12-08 12:10:59] error: z2m: Error while starting zigbee-herdsman
[2024-12-08 12:10:59] error: z2m: Failed to start zigbee
[2024-12-08 12:10:59] error: z2m: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start.html for possible solutions
[2024-12-08 12:10:59] error: z2m: Exiting...
[2024-12-08 12:11:00] error: z2m: Error: Failed to start EZSP layer with status=HOST_FATAL_ERROR.
Did either of you find a fix, happened to mine after latest update.
Edit - In my case this was down to the “silicon labs multiprotocol” add on. I flipped the dongle over to a later firmware recently for ember. It did work for a few updates but this time round was being locked by this add on, I forgot i had this enabled. So just turned off start on start up and restarted and all ok again.
Will probably remove this add on now as never used it for matter anyway
