This video:-
Is suggesting that EZSP is depreciated, at least for Z2M, but it also says the upgrade to Ember is compatible with ZHA. Has anyone tried this to see if it works ?
This video:-
“Ember” is just a newer replacement for z2m’s “ezsp” driver, for backward comaptibility they just had to give it a different name.
The stick and stick firmware remain the same.
The “ember” driver does require a newer version of the EZSP firmware than the “ezsp” driver does, but not a bleeding edge or ZHA incompatible version.
So is there any point upgrading the firmware on the stick if you are running ZHA ?
Not unless you are having issues. If it ain’t broke, don’t fix it.
I’m just thinking about future device compatibility. But yeah, no issues so far.
