Sonoff Dongle Max with Home Assistant for Matter
I had my first Matter devices, thinking my Nest hub v1 also supported Matter, not…
So I ordered the Sonog Dongle Max, and I want to use it over a wired network (POE)
How do i configure this dongle as a Matter Border Router ? I will receive it tomorrow.
I read something about Open Thread Border Router service and already installed it, but it asks for a REST API
I recommend reading the official docs on Thread and Matter, as well as the distinction between Integrations and Apps (formerly Add-ons), which should greatly help with your understanding of how all the pieces fit together (for example, it sounds like you did not install the OTBR service, you enabled an integration which is designed to communicate with a server App (Add-on), which also needs to be installed).
Did you manage to get it working over WIFI or ethernet? I couldent, needed to specify device anyway in the Open Thread Border Router addon and that only shows when its plugged via USB. Such a dissapointment this device.
Is this what you are looking for?
