Today arround 12:00 all my tasmota installed devices dropped out off service, When i reboot them via te button or by unplugging and plugging them back in they will apear in Home-Assistant but after a Couple off seconds the are gone again.
How far are they from your Wi-Fi access point, do you run multiple access points?
They are two meters from the accespoint, and I only run 1
The weird part is that it always worked for like a year
Do you have another sonoff you can try?
Nope every single one in the house does not work and I do not have a spare one
I have found the problem, my router that was provided bt my ISP has an error with the wifi modules and blockes devices. I got an old router and connect it. and everthing worked fine again.
