Sonoff Dual R3 (switches only in HA)?
The Sonoff Dual R3 has both 2 switches and 2 separate measuring paths. In the EWeLink app, I can both operate the switches and I can see the measurement paths as well (Volt/Amp/Watt)
In HA, I can only use the switches.
Even though I switch the unit to measurement …. is it not supported in HA ?
How can I activate the measuring paths in HA as well.
Has someone already integrated the Dual R3 and can give me a hint ?
I have the same issue… Have you figured it out?
No, sorry I could not solve the problem.
It looks like, not so many members in this Community are using Sonoff in its original form an even less are using the newer switches.
It’s a shame cause the Dual R3 switches are offering much more compared to the old switches.
Regards … WoWu
Did you try this integration ?
The dual R3 seems not yet supported but there is a request (#482) for enhancement…
yes, I am using that software. I can see the Dual R3, but only the two switches.
So far it seems to be supported but the R3 provides also the electrical measurements (Volt, Amp, Watt, ) but I can just see these components in the original EWlink application but not in the HA App. So these parameters seems not to be supported (yet ?).
Best
WoWu
I use Tasmota on my sonoff devices including 2 r3’s everything seems to work fine with this:
That’s the problem ….
For several reasons I can not use flashed Units.
One of the reason is, that the switches are distributed over a wide area and run over several different LANs … so the point of combination is in China.
So far, so good … I can live with it.
How ever there are other reasons as well.
But if the unflashed version of Sonoff is supported in HA … why not all Switches and why not all switch parameters ?
But thanks for the reply. I still hope, that someone change that (i can’t unfortunately).
Best
WoWu
Did you integrated?? I have the same problem.
The sonoff application in HA recently got an update.
This covers also DualR3
Since than I can use the V/A/W of the dual switches as well.
regards
ww
Do you guys know how to check the measured consumption of power going through the dual R3?
I can see the wattage, but cannot measure it over a period of time
I receive my consumption from the eWeLink account. They keep it for 6 month.
I don’t have a Methode of reading it out directly in HA but I am sure, the nerds have a method of doing this ….
