Just a question…what hardware do u guys here for the blinds motor . Would like to add those to my house and system …I also want to add physical buttons for my wife …wife acceptance is very important
First of all, thank the creator of the code for the work.
Second, I wonder if you can share the structure to follow to sort the blinds like this, I’m a bit new to this and I want to do it like you.
I tried to stop seeing the clocks and I did not get it either.
Thank you
*sorry for my engish, i help me with traductor.
I found this diagram online that should help with the wiring.
It is exactly how I wired my window cover.
The switch changes the states of the relays in the Line Out 1 & 2.
To get the structure to sort the blinds, I used ‘groups’.
Define a group for each set of entities that you would like grouped together like so:
sitting_room_shutters:
view: no
entities:
- cover.sitting_room_front_shutter
- input_number.sitting_room_front_shutter_position
- cover.sitting_room_door_shutter
- input_number.sitting_room_door_shutter_position
- cover.sitting_room_back_shutter
- input_number.sitting_room_back_shutter_position
Then add the groups to a view like so:
shutters_view:
view: yes
entities:
- group.bedroom_shutters
- group.sitting_room_shutters
- group.dining_room_shutters
- group.other_shutters
All this goes in a file called groups.yaml in the same folder as the configuration.yaml. (create it if it is not there)
Put this line:
group: !include groups.yaml
in your configuration.yaml
Check Config and restart.
Hi. I’ve tried a bit and I think I have a lot of things to do besides these.
I have currently operating 1 shutter with the code of the first post.
In config.yaml, I have the windows and time position. I think I should get it out of there but as soon as I play some time the blind never stops sending a signal.
I think I should integrate this into covers?
And on the other hand I think that the file automatitions.yaml, should I redo it for each one of the blinds? ** I do not understand the ration between covers or groups and automations. That is to say in autamations we have id301 but nowhere do I see where that id is called to make it work.
I’m very new with this,
Could you hit me all the files that are related to the blinds? or by message if it is very large. I think I do not do it.
Thank you
Hi
You can put everything in the configuration.yaml if you like, but this gets very big, very messy, very quickly.
You would be better off splitting it into multiple files. There is ample documentation on this in the Home-Assistant help files. It may prove tricky at first but it can be done.
A cover is a component of HA like switch, sensor
An automation reacts to events to make things happen. The automation ID is used by HA.
A group is a way to put entities in one place eg on the frontend of HA.
My configuration.yaml contains these references:
automation: !include automations.yaml
automation old: !include_dir_merge_list automation/
cover: !include covers.yaml
input_number: !include input_numbers.yml
timer: !include timers.yml
In the CONFIG folder create files that you need (if not already there):
covers.yaml (contains all cover definitions)
input_numbers.yaml (contains all input_number definitions)
groups.yaml
timers.yaml (contains all timer definitions)
etc
Also, it you have multiple covers you need automations for each cover.
I made a folder ‘automation’ that contains the automations for each cover (see screen grab).
Each of these files contains the automation for each cover.
Each cover will have a different entity_id and the automations have to be unique for that cover.
This is my master_bedroom_shutter.yaml for example:
- id: '301'
alias: Master Bedroom - MQTT Button1 OFF (up)
- payload: 'OFF'
platform: mqtt
topic: stat/sonoff03/POWER1
- service: timer.cancel
entity_id: timer.master_bedroom_shutter_up
- id: '302'
alias: Master Bedroom - MQTT Button2 OFF (down)
- payload: 'OFF'
platform: mqtt
topic: stat/sonoff03/POWER2
entity_id: timer.master_bedroom_shutter_down
- id: '303'
alias: Master Bedroom - Timer stopped
- platform: event
event_type: timer.finished
event_data:
- platform: event
event_data:
- service: cover.stop_cover
entity_id: cover.master_bedroom_shutter
- id: '311'
alias: Master Bedroom - MQTT Button1 ON (up)
- payload: 'ON'
platform: mqtt
- service: timer.start
duration: 00:00:16
- id: '312'
alias: Master Bedroom - MQTT Button2 ON (down)
- payload: 'ON'
platform: mqtt
duration: 00:00:16
- id: '411'
alias: Master Bedroom - Position UP
platform: time
seconds: '/1'
condition: state
entity_id: 'timer.master_bedroom_shutter_up'
state: 'active'
data_template:
entity_id: input_number.master_bedroom_shutter_position
value: "{{ states.input_number.master_bedroom_shutter_position.state | int + 1 }}"
- id: '412'
alias: Master Bedroom - Position Down
platform: time
seconds: '/1'
condition: state
entity_id: 'timer.master_bedroom_shutter_down'
state: 'active'
data_template:
value: "{{ states.input_number.master_bedroom_shutter_position.state | int - 1 }}"
#- id: '511'
# alias: Master Bedroom - Set Position Down
# trigger:
# platform: state
# entity_id: input_number.master_bedroom_shutter_set_position
# condition:
# condition: template
# value_template: "{{ (states.input_number.master_bedroom_shutter_position.state | int) > ((((states.input_number.master_bedroom_shutter_set_position.state | int ) * 16 )/100) | int) }}"
# action:
# - service: timer.start
# data_template:
# entity_id: timer.master_bedroom_shutter_down
# duration: "{{ '00:00:%02d' | format( ((states.input_number.master_bedroom_shutter_position.state | int) - ((((states.input_number.master_bedroom_shutter_set_position.state | int ) * 16 )/100) | int) ) | abs ) }}"
# - service: cover.close_cover
# entity_id: cover.master_bedroom_shutter
#- id: '512'
# alias: Master Bedroom - Set Position UP
# trigger:
# platform: state
# condition:
# value_template: "{{ (states.input_number.master_bedroom_shutter_position.state | int) < ((((states.input_number.master_bedroom_shutter_set_position.state | int ) * 16 )/100) | int) }}"
# action:
# data_template:
# entity_id: timer.master_bedroom_shutter_up
# - service: cover.open_cover
I am not using the Set_position feature and that is why the code is commented out. I have also removed some of the code from the original as it is not useful to me.
This is the input_number.yaml for that cover:
master_bedroom_shutter_position:
min: 0
max: 16
and the timers.yaml:
master_bedroom_shutter_up:
master_bedroom_shutter_down:
You need to change all MQTT topics, aliases, entity_id’s, timer durations, etc., for each cover. Don’t forget the duration in ‘value_template’ in id511 & id 512. If you compare my files with the original you will see the differences.
Do 1 cover first. Get it working as you wish, then duplicate all the automations for each cover in a new yaml and do all the config changes one cover at a time. Use a sensible and clear naming strategy to help avoid confusion. It’s a long, tedious job.
Make sure that the first cover you do is working properly before duplicating.
Happened to me and had to edit all the automations for 11 covers. That’s 99 automations. Boring.
Hope this helps.
Thank you very much for your answer.
I undestardand with this “tutorial” a lot of things.
I go to start work with this, thank you thank you thank you
Hi Pierre,
I have it working but i have problems, i think is a code error easy but i dont look it.
The blind up / down but never stop. When timer finish the relay no stop. And when i adjust the set position bar nothing happens in the blind (in menu yes, timers start count and the bar move)
I paste all the codes that have to do with the blind.
configuration.yaml
script: !include scripts.yaml
cover: !include cover.yaml
switch: !include switch.yaml
timer: !include timers.yaml
input_number: !include input_numbers.yaml
timers.yaml
persiana_salon_pequena_up:
duration: '00:00:16'
persiana_salon_pequena_down:
input_numbers.yaml
persiana_salon_pequena_position:
name: "Posición persiana"
initial: 5
min: 0
max: 16
persiana_salon_pequena_set_position:
name: "Ajustar posición persiana"
initial: 5
min: 0
max: 100
groups.yaml
persianas_salon:
view: no
entities:
- cover.persiana_salon_pequena
- input_number.persiana_salon_pequena_position
- input_number.persiana_salon_pequena_set_position
shutters_view:
view: yes
entities:
- group.persianas_salon
cover.yaml
covers:
persiana_salon_pequena:
friendly_name: "Salón pequeña"
position_template: "{{ (((states.input_number.persiana_salon_pequena_position.state | int) * 100)/16 | int) }}"
open_cover:
- service: mqtt.publish
topic: 'cmnd/sonoff_d1/power2'
payload: 'OFF'
topic: 'cmnd/sonoff_d1/power1'
payload: 'ON'
close_cover:
payload: 'OFF'
payload: 'ON'
stop_cover:
payload: 'OFF'
payload: 'OFF'
and persiana_salon_pequena.yaml (inside dir automation)
- id: '301'
alias: Window - MQTT Button1 OFF (up)
hide_entity: True
- payload: 'OFF'
platform: mqtt
topic: stat/sonoff_d1/POWER1
entity_id: timer.persiana_salon_pequena_up
- id: '302'
alias: Window - MQTT Button2 OFF (down)
hide_entity: True
- payload: 'OFF'
platform: mqtt
topic: stat/sonoff_d1/POWER2
entity_id: timer.persiana_salon_pequena_down
- id: '303'
alias: Window - Timer stopped
hide_entity: True
- platform: event
event_data:
- platform: event
event_data:
entity_id: cover.persiana_salon_pequena_cover
- id: '311'
alias: Window - MQTT Button1 ON (up)
hide_entity: True
- payload: 'ON'
platform: mqtt
condition: template
value_template: '{{ as_timestamp(now()) - as_timestamp(states.input_number.persiana_salon_pequena_set_position.last_updated) > 3 }}'
duration: 00:00:16
- id: '312'
alias: Window - MQTT Button2 ON (down)
hide_entity: True
- payload: 'ON'
platform: mqtt
condition: template
duration: 00:00:16
- id: '411'
alias: Window - Position UP
hide_entity: True
platform: time
seconds: '/1'
condition: state
entity_id: 'timer.persiana_salon_pequena_up'
state: 'active'
data_template:
entity_id: input_number.persiana_salon_pequena_position
value: "{{ (states.input_number.persiana_salon_pequena_position.state | int) + 1 }}"
- id: '412'
alias: Window - Position Down
hide_entity: True
platform: time
seconds: '/1'
condition: state
entity_id: 'timer.persiana_salon_pequena_down'
state: 'active'
data_template:
value: "{{ (states.input_number.persiana_salon_pequena_position.state | int) - 1 }}"
- id: '511'
alias: Window - Set Position Down
hide_entity: True
platform: state
entity_id: input_number.persiana_salon_pequena_set_position
condition: template
value_template: "{{ (states.input_number.persiana_salon_pequena_position.state | int) > ((((states.input_number.persiana_salon_pequena_set_position.state | int ) * 16 )/100) | int) }}"
data_template:
duration: "{{ '00:00:%02d' | format( ((states.input_number.persiana_salon_pequena_position.state | int) - ((((states.input_number.persiana_salon_pequena_set_position.state | int ) * 16 )/100) | int) ) | abs ) }}"
- id: '512'
alias: Window - Set Position UP
hide_entity: True
platform: state
condition: template
value_template: "{{ (states.input_number.persiana_salon_pequena_position.state | int) < ((((states.input_number.persiana_salon_pequena_set_position.state | int ) * 16 )/100) | int) }}"
data_template:
Its all, i dont find the problem.
** your timer.yaml and input numbers.yaml (not finish in .yaml, finish in .yml, its an error or why?
Thank you
Go to the web interface of the sonoff by typing its IP address in a browser. Click ‘console’. Type pulsetime1 116 and then pulsetime2 116. This will switch off the relays after 16 seconds.
Yaml or yml doesn’t matter as long as it is the same in the !include command and the actual file name.
I use text wrangler to edit yaml/yml files. It uses yml.
This solution I think is doing it wrong, if in the original way it worked well I think that with the structure of now I should also get it.
I will continue testing to see if I locate the problem.
Thanks Pierre
fixed up!!!
it was a silly mistake,
I was keeping xxxxxx_cover in automation, when in the group we had eliminated that termination.
Glad you found a solution.
Thanks to your help I have achieved it.
I need to generate a master to see if I get it.
And two details,
1, in the frontend I have managed not to see the automation, but in homekit (iphone) I can not hide them,
I have tried with this code
homebridge_hidden: true
Under -id xxx but it tells me that in automation you can not do that command.
2, can you hide the round clocks in fronted?
The hidden attribute is in ‘ customisation ‘ not in ‘automation’
However I used this code in configuration.yaml
homekit:
filter:
include_domains:
- cover
- switch
- sensor
Check this out:
Don’t know what you mean by ‘round clocks’ Can you post a picture?
again thank you very much, I’ve already hidden from homekit.
The clocks too, it was something basic in ha, but I think I started with something very difficult. I have achieved it and I am understanding more things.
Thanks pierre for your help!
Hello. A super job. a question: I have configured everything as you did. the cover.stop service does not work for me. do not stop the blinds. I have a 4 channel sonoff. Thanks for your help
From own experience, if you are using the totally original code, you have changed the name badly in some place.
Which hardware are you all using?
thank you for this addition, unfortunately my Cover State is displayed endless as „opening“, closed will be Displayed correctly. Did I miss to adjust something?
Thank you in advance.
