Sonoff Dual Window Cover with set position
@bkbilly thank you so much for this very intested post! very usefull
in my case, seems that everything is working fine but I have some problem with command timer. when I turn down the blind and stop halfway then when I start to go down again it does not start from the time that remained. it’s starting from the total timer configured… i have the comand recorder configured…
any idea why is not recording the timers?
thanks!
Hello takezo,
I’m interesting by your work can you share it ? please
Did you find the issue concerning timer ?
in my case several bug appear.
Thank you for your help.
sorry for replying so late … Here it’s the setup i have implemented :
configuration.yaml:
timer:
    window_1_up:
    duration: '00:00:30'
  window_1_down:
input_number:
  window_1_position:
    name: "Window Position"
#    initial: 100
    min: 0
    max: 100
    step: 1
  window_1_set_position:
    name: "Window Set Position"
#    initial: 100
    min: 0
    max: 100
    step: 1
#MQTT Xiaomi Zigbee
switch:
  - platform: "mqtt"
    state_topic: "zigbee2mqtt/0x00158d0003e82ee9"
    availability_topic: "zigbee2mqtt/bridge/state"
    payload_off: "OFF"
    payload_on: "ON"
    value_template: "{{ value_json.state_l1 }}"
    command_topic: "zigbee2mqtt/0x00158d0003e82ee9/l1/set"
  - platform: "mqtt"
    payload_off: "OFF"
    payload_on: "ON"
    value_template: "{{ value_json.state_l2 }}"
    command_topic: "zigbee2mqtt/0x00158d0003e82ee9/l2/set"
cover:
    covers:
      window_1_cover:
        friendly_name: "Cover door"
        position_template: "{{ (states.input_number.window_1_position.state | int) }}"
        open_cover:
          - service: mqtt.publish
              topic: 'zigbee2mqtt/0x00158d0003e82ee9/l1/set'
              payload: 'OFF'
              topic: 'zigbee2mqtt/0x00158d0003e82ee9/l2/set'
              payload: 'ON'
        close_cover:
              payload: 'OFF'
              payload: 'ON'
        stop_cover:
              payload: 'OFF'
              payload: 'OFF'
automations.yaml
- id: '301'
  alias: window_1 - MQTT Button1 OFF (up)
  - payload: 'OFF'
    platform: mqtt
    topic: zigbee2mqtt/0x00158d0003e82ee9/l2/set
  - service: timer.cancel
    entity_id: timer.window_1_up
  - service: input_number.set_value
    data_template:
      entity_id: input_number.window_1_set_position
      value: >-
          {{ states.input_number.window_1_position.state }}
- id: '302'
  alias: window_1 - MQTT Button2 OFF (down)
  - payload: 'OFF'
    platform: mqtt
    topic: zigbee2mqtt/0x00158d0003e82ee9/l1/set
    entity_id: timer.window_1_down
    data_template:
      value: >-
- id: '303'
  alias: window_1 - Timer stopped
  - platform: event
    event_type: timer.finished
    event_data:
  - platform: event
    event_data:
  - service: cover.stop_cover
      entity_id: cover.window_1_cover
- id: '311'
  alias: window_1 - MQTT Button1 ON (up)
  - payload: 'ON'
    platform: mqtt
  condition:
    condition: template
    value_template: '{{ as_timestamp(now()) - as_timestamp(states.input_number.window_1_set_position.last_updated) > 3 }}'
  - service: timer.start
      duration: 00:00:30
- id: '312'
  alias: window_1 - MQTT Button2 ON (down)
  - payload: 'ON'
    platform: mqtt
  condition:
    condition: template
      duration: 00:00:30
- id: '411'
  alias: window_1 - Position UP
    platform: time_pattern
    seconds: '/1'
  condition:
    condition: state
    state: active
    data_template:
      entity_id: input_number.window_1_position
      value: >-
          {% set step=100/30 %}
          {% if (states.input_number.window_1_position.state | float + step) < 100 %}
            {{ states.input_number.window_1_position.state | float + step | int }}
          {% else %}
            100
          {% endif %}
- id: '412'
  alias: window_1 - Position Down
    seconds: '/1'
  condition:
    condition: state
    state: active
    data_template:
      value: >-
          {% if (states.input_number.window_1_position.state | float - step) > 0 %}
            {{ states.input_number.window_1_position.state | float - step | int}}
          {% else %}
            0
          {% endif %}
- id: '511'
  alias: window_1 - Set Position Down
    platform: state
  condition:
    condition: template
    value_template: >-
        {{ (states.input_number.window_1_position.state | int) >
           (states.input_number.window_1_set_position.state | int) }}
    data_template:
      duration: >-
          {{ '00:00:%02d' | format(((
              (states.input_number.window_1_position.state | int) -
             ) * 33 /100) | int | abs )
  - service: cover.close_cover
- id: '512'
  alias: Window_1 - Set Position UP
    platform: state
  condition:
    condition: template
    value_template: >-
        {{ (states.input_number.window_1_position.state | int) <
    data_template:
      duration: >-
             ) * 30 /100) | int | abs )
  - service: cover.open_cover
As I said, everything works well: it goes up, it goes down correctly according to the automation but the manual option does not work and it does not save position if I stop at 30%
any support for this will be welcome!!
Hey all!
First, big thanks to all on the forum for sharing your experiences and knowledge. I am quite fresh in HA…I managed to configure my sonoffs and other devices and I have few Dual R2 for blinds with physical switches…and now the question: on this diagram is live wire from mains? I had to ask because I will wire it and don’t want to burn the module…
Thanks!!
The buttons are not connected to the mains.
The only live wires are on the right side of the diagram. The Red is the mains (220v), Blue Neutral, and the Black/Brown controls the motor for the blinds. The Green one I don’t know why is on the diagram, but my blinds don’t have this extra wire.
As long as you put the Neutral and Line on the correct place, you won’t fry anything.
Thanks Basilis!
But how exactly works button on board?
I connected with physical switch (1-0-2) (it’s a switch not a push button) and if I press on 1 - nothing happens, then if I put switch back to 0 the motor goes up. To stop the motor I have to put switch back to 1 and then back to 0…
Does anyone have a hint how to have sonoff r2 dual with physical switch (1-0-2) - my wife will go crazy if I change switches to touch :upside_down_face:
You can’t have any blinds with switches because you risk on destroying the motor and if it is how you found them, someone didn’t know their job.
I would recommend changing them into buttons. No need to have touch buttons, just the regular ones for blinds. They look like switches but they recoil once you let go.
Thank you!! I finally managed it, I found buttons with the same design…and it works! You were right,it could burn motors…
Now I can proceed to phase 2…cover and position :grin:.
One stupid question…since I’m a noob…
I’m using sonoffs (not flashed to Tasmota) with AlexxIT/SonoffLAN in HA…and before even trying your great project for cover with set position, … would it even work since there is no MQTT?
I didn’t know about this project. Seems interesting.
As for your question, I think that with a few modifications it can be achieved.
I would recommend though to leave everything as it is and create some automations that send status of each button change to an MQTT server and listen to the specific events.
This is just a draft to get an idea of what I am talking about:
- alias: Button1_Changed_on
    - platform: state
      entity_id: switch.button1
      to: 'on'
        topic: stat/window_1/POWER1
        payload: 'on'
- alias: Button1_Set_on
    - platform: mqtt
      topic: cmnd/window_1/power1
      payload: 'OFF'
    - service: switch.turn_on
You should create 2 more for button2.
Thanks! Tried with mqtt, success! Now have to configure buttons with power in right way, something changed when I adjusted code to my sonoff’s…
Pretty new in Home Assistant, I’ve been struggling for days to implement this in my setup (not for it being complicated but for my lack of knowledge).
Finally, I got it working and with configuration splitted into several files, but I am having a little problem:
I don’t know how to exactly calibrate the seconds that the blind is going up or down. Let me please explain:
I have a sonoff dual r3 device, flashed with tasmota, changed to be seen as a blind controller. I set pulsetime1 & pulsetime 2 to 120 (just testing, attached to nothing).
Then I go to automations.yaml (as a matter of fact, I go to my “ventana1.yaml” file inside the automation folder) and change every “16” by a “20”. Reboot the machine (just in case), and try the “down” button.
Now in “window 1 down” it starts a count down from 24, which suddenly stops at 5. Window Position stops at “5,0”, and both arrows remain enabled as it didn’t go to 0.
Could you please help me figure out which numbers should I use, and if I have to do it in tasmota console, in automations.yaml, both, etc.?
Thanks.
