Same by me, the physical buttons do not work.
Does someone has an fix?
Hi, I have read all the topic and applied the custom timer component to my configuration. Now I can control my ride shutter from hassio, Google assistant and switches without problems.
The only thing I can’t adjust is about different position shutter reach depending if i’m closing or opening it.
For instance, if shutter is closed and I set to open it 50% the reached position is correct but it is not the same when the shutter is all open and I want to close it 50%. In this case the shutter stops far from 50%…near to completely close. I suppose it is a different speed of the engine opening or closing the shutter. Is there a way to solve it?
Thanks to everyone will give advices.
Hi, do you think it’s possible to adapt your code to ESPHome? Thanks
It’s already there - https://esphome.io/components/cover/time_based.html
I’m using sonoff touch to operate my roller shutters. I can set position and open/close them from HomeAssistant and Google Assistant
Dear all thank you so much for the code and continuous improvement. I have one problem with this code… I’m not able to get the position sliders to be updated when I press the arrows or when I use the physical buttons. In the past (one year ago maybe) I was able to get this working but now it does not work.
Any advice?
You will have to check that the topic stat/window_1/POWER1
is sent correctly to mosquitto server which is defined on the automations.yaml file.
Thank you so much!!! I had a issue with topics definition overall and MQTT that was causing this behaviour and not the code itself. After setting up the devices correctly everything worked as expected!!! Great code!
Best regards
Hi, Thanks for sharing the project. I am using my shutters with your esphome code on an Olimex esp32 platform. However, I would like to have set position and Windows position control in the home assistant. This seems possible only with the mqtt protocol. I, however, would like to avoid mqtt because when the server is off I would like to be able to close the blinds from the physical buttons. In your opinion, would it be possible to set simple buttons and relays in esphome without using the cover and then arrange the cover in the Home assistant? can you help me?
For controlling the cover with physical buttons you will have to change the pin number from the binary_sensor (GPIO09 & GPIO00). This way the server can be off and still be able to control the cover.
Though, if you want to set the position I believe that this might help: set_position(0.5), but I don’t know exactly how to use it so you might want to try it out.
Edit: This might also work by replacing it on on_press
and on_release
- cover.control:
position: 50%
Now my code is
binary_sensor:
platform: gpio
pin:
number: GPIO02
mode: INPUT_PULLUP
inverted: True
on_press:
platform: gpio
pin:
number: GPIO03
mode: INPUT_PULLUP
inverted: True
on_press:
switch:
cover:
platform: time_based
open_action:
close_action:
stop_action:
… but i don’t see the slider position
in HA i see only
Hi, could you tell me exactly where to write
- cover.control:
position: 50%
Hi Pierre, can you help me?
I would like to add to my cover in esphome a slider that marks the position of the curtain. My code is currently:
binary_sensor:
- platform: gpio
pin:
number: GPIO02
mode: INPUT_PULLUP
inverted: True
on_press:
- cover.open: my_cover
on_release:
- cover.stop: my_cover
- platform: gpio
pin:
number: GPIO03
mode: INPUT_PULLUP
inverted: True
on_press:
- cover.close: my_cover
on_release:
switch:
- platform: gpio
pin: GPIO04
interlock: &interlock [open_cover, close_cover]
- platform: gpio
pin: GPIO05
interlock: *interlock
cover:
- platform: time_based
open_action:
- switch.turn_on: open_cover
open_duration: 4s
close_action:
- switch.turn_on: close_cover
close_duration: 4s
stop_action:
- switch.turn_off: open_cover
- switch.turn_off: close_cover
what do I have to add to see also the position slider besides the forward, back and stop buttons?
Thank you!!!
I used the slider-entity row: https://github.com/thomasloven/lovelace-slider-entity-row
type: entities
entities:
- entity: cover.back_bedroom_shutter
full_row: true
type: 'custom:slider-entity-row'
which gives:
I use slider-entry-row and it works perfectly. Only one problem: when I restart home assistant, the slider is setted to 0 even if the shutter is in other position. And on my sonoff dual (whit tasmota and shutter configuration) the position is right. Thers’s an automation to announce the current position that I have to call on home assistant start?
This is my cover configuration:
- platform: mqtt
availability_topic: "tele/sonoffdual002/LWT"
state_topic: "stat/sonoffdual002/RESULT"
command_topic: "cmnd/sonoffdual002/Backlog"
value_template: '{{ value | int }}'
qos: 1
retain: false
payload_open: "ShutterOpen1"
payload_close: "ShutterClose1"
payload_stop: "ShutterStop1"
state_open: "ON"
state_closed: "OFF"
payload_available: "Online"
payload_not_available: "Offline"
optimistic: false
set_position_topic: "cmnd/sonoffdual002/ShutterPosition1"
position_topic: "stat/sonoffdual002/SHUTTER1"
Hi all, today I will receive my Sonoff Dual and I will setup this project, so thanks for sharing!
This is al very new for me and I am still a bit concerned about a possible short circuit and breaking the motor. I know that power1 OFF is being published before power2 ON, but what if something is wrong with publishing power1 OFF? Then power2 ON should not be published. Is this possible or should I trust HA for 100% publishing them in the right order?
There is an interlock option for both solutions which only enables one relay at a time, though in my motor if both are pressed it just stops.
Thanks, I founfd it! Very useful
Hi, I’m trying to enter the availability_template command but I’m getting an error. Can you help me?
covers:
window_cover_cucina:
friendly_name: "Cucina"
availability_template: 'tapparella/status'
position_template: "{{ (((states.input_number.window_position_cucina.state | int) * 100)/39 | int) }}"
open_cover:
- service: mqtt.publish
topic: 'tapparella/switch/tenda_cucina_giu/command'
payload: 'OFF'
topic: 'tapparella/switch/tenda_cucina_su/command'
payload: 'ON'
close_cover:
payload: 'OFF'
payload: 'ON'
stop_cover:
payload: 'OFF'
payload: 'OFF'
this setup could be also valid to XIAOMI AQARA ZIGBEE to control covers?
autoanswer, yes it’s working… !!!
but i have some issues with the "set_position! but im working in progress to fix it.
