Some progress here, problem was PIBCAK. Resolved. ( had an incorrect name for one of my time counters).
However, now I have a different problem, that I don’t fully understand.
None of my sliders work as expected, and one seems to be the reverse of all of the others.
I also find that composing questions to post here is the best way to troubleshoot. While explaining the problem in words, it really helps to go back and check the config… Like you PierreScerri - my POWER1 is up/close and my POWER2 is down/open.
I modified my covers.yaml to reflect the up / down timer for POWER 1 and POWER 2 respectively. It seems to be working better now.
However, the Office Shutter position never gets set… it always stays at 100%. when I use the buttons to control that shutter. If I use the slider, the shutter moves accordingly, and the position is set correctly when it stops moving… unless I set the position with the slider to 0% - then it stays at 100%. Everything is set up the same as the other shutters, so this is a mystery to me.
NONE of the other shutters sliders work to set the position. I try to set the position to say 50% from 100% - and it stops at 97%? However, their position is correctly reported as closed or 100% when fully opened or closed.
So frustrating when the setup is identical (probably isn’t but I cannot see…
One other thing… there’s always one thing isn’t there… When I use a script to invoke the closure of all shutters, once closed, all positions update, apart from my office shutter, which remains at 100% (open). That’s also another small issue… when closed (0%) the slider shows closed. When open (100%) the slider shows 100% (and not open). Can we not have a consistent display and show open for 100%, closed for 0% and the %age for anything in between?
@Seweryn_Zeman THanks for your work here… using it and its working well.
I found my problem after leaving things alone for some time… (A break, and coming back with fresh eyes is often the solution!!! My problem was my MQTT topic. I organise my topics under “upstairs” and “downstairs”. My office is downstairs, and in the automation, a copy paste error meant I had upstairs in the mqtt topic, not downstairs… @PierreScerri - of course, you were right, it was a typo!!! hence the problem. All working well now. Will try the new code to see if the Unable to remove unknown listener warnings go away.
Hi, I have just configured everything with time_counter but despite having put 20 seconds of time the relay always stops at 10 seconds.
It also doesn’t fit the position and I don’t know how to calibrate.
here is my configuration.
can you help me?
I had forgotten the pulsetime command active on the sonoff, now the time is respected. But the problem remains that the slide does not match.
For example if I put the cursor on 25% he moves up to 36% or 38% etc.
How can I solve this problem?
This error shows up when you create a new timer and what is returned is a listener on which you can call .cancel(). If timer ended successfully this listener is wiped out so you cannot call .cancel() on it anymore. If you try – you get this one.
I had mine Unable to remove unknown listener because of async executions which didn’t lined up.
Hi to everybody, anyone have some idea how to implement the duration of timers in Node_red? Call service tab on node_red don’t accept data_template but only data
Hi, were you able to solve your problem? I used your automation as the basis for mine but it reports an error in the position part. Could you help me? good day
Yes Asino,off course work, this platform work like a timer, you need to set the time need for full open and for full close the cover, than when you for example set position to 20% your cover will be in open function for 20% time of your full open time (eg. full open time 30s - set 20% position: 30/100*20= 6s in open function).
Let me know if you need some help for properly set this platform, just for your info, the tilt position work only for suncover with motorized tilt function.
Thank you for your support, you are right after several attempts the component works on the gray scale. All that remains is a problem not related to the component. I control the device through a double relay of the quino that I also control with two physical buttons. It happens that if I control the blinds with the physical buttons the component does not detect the displacement. Now I’m trying to create the automations associated with the relays closing but for now without success. good day.
HI Asino123, one solution for your issue is using a timer that’s both activated by your switch and the Home Assistant (set position or switch). I’ve used the solution provided below along with timedcover:
Could you please post one of automatization scripts?
Not sure what you meant, but also have a problem when i operate physical buttons it doesnt update position.
Also, have you found a way to disable tilt position slider ? I guess most of us dont need tilt…
