Since an update - I don’t exactly know which version - I’m getting these errors in my MQTT broker:
541482376: New connection from 192.168.178.144 on port 1883. [ERROR] Auth error with DVES_USER 1541482380: Socket error on client <unknown>, disconnecting. 1541482380: New connection from 192.168.178.164 on port 1883. [ERROR] Auth error with DVES_USER 1541482385: Socket error on client <unknown>, disconnecting. 1541482391: New connection from 192.168.178.144 on port 1883. [ERROR] Auth error with DVES_USER
Not an expert at all… but why do you have discovery enabled and a discovery prefix if you are manually configuring the switches?
Also, looks like you have a DVES_USER - that’s a default user right? do you have a password set? Are you using hass.io? Did you set a local username and password in the broker? I deleted the mqtt section from my config yaml as the new add-on and mqtt integration doesn’t require it. (I didn’t enable mqtt discovery in the integration)
The new add-on version 3 seems to have caused some people some grief
Can someone tell me how to get this working again please? Why do we keep getting these breaking changes all the time, then I need to spend hours trying to fix it. I’ll have to turn off the auto updates, it’s infuriating!
I previously had this config in my configuration.yaml file:
1: I’ve commented my mqtt and switch part in configuration.yaml file
2: I’ve entered a username and password in the mqtt broker
3: restarted hass.io and setup the mqtt integration
