Hi!
I’ve installed a Hassio on raspberry pi 2.
I have 3 sonoff’s configured to comunicate with hass by mqtt.
Everything works fine when is running at home assistant 0.49.1.
After installing a hassio i have a problem to configure sensors
The following components and platforms could not be set up:
mqtt
sensor.mqtt
Please check your config
This is my configuration file with sensors section:
mqtt:
- platform: mqtt
state_topic: “salon/bme280/Temperature”
friendly_name: Temperatura
qos: 0
unit_of_measurement: “°C” - platform: mqtt
state_topic: “salon/bme280/Humidity”
qos: 0
unit_of_measurement: “%” - platform: mqtt
state_topic: “salon/bme280/Pressure”
Do you see any problem here?
Thanks for help!
