So I built a home automation system for my pool and hot tub control. Heater thermostat was out so used a sonoff TH16 to monitor hot tub temp and kick heater power off at 104. Problem now is that I made the mistake of upgrading firmware to 3.3 and now the Temp does not update… the hot tub got to 120 degrees.
Any fixes available yet to have the TH16 update temp?
This sonoff/eWelink componet has been great until this latest sonoff firmware upgrade.
Using Hass.io Home Assistant and Node Red for automation.
Oh right, the 3.3.0+ is the problem I guess. My POW R2 with that version of firmware is doing the same. The refresh rate do not work unless you open the ewelink. Maybe some king of downgrade would help if there is a chance.
Jumped ship from sonoff software to flashing ESPhome firmware and all is now good. Was hoping to stay with sonoff and not flash custom firmware but it was a breeze.
Hi Peter,
i’ve Hassio (in a RPI3b) working. and i’ve one sonoff Led Lamp B. i’ve tried to install your component but i got this error :
2019-09-25 10:26:14 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
File “/usr/src/homeassistant/homeassistant/helpers/entity.py”, line 266, in async_update_ha_state
self._async_write_ha_state()
File “/usr/src/homeassistant/homeassistant/helpers/entity.py”, line 300, in _async_write_ha_state
state = self.state
File “/usr/src/homeassistant/homeassistant/helpers/entity.py”, line 554, in state
return STATE_ON if self.is_on else STATE_OFF
File “/config/custom_components/sonoff/switch.py”, line 75, in is_on
self._state = self.get_state()
File “/config/custom_components/sonoff/init.py”, line 648, in get_state
return device[‘params’][‘switch’] == ‘on’ if device else False
KeyError: ‘switch’
Hi I get this on the log file:
[custom_components.sonoff] found new region: >>> as <<< (you should change api_region option to this value in configuration.yaml)
This is my config:
sonoff:
username: ‘+97254453642’
password: ***********
scan_interval: 60
grace_period: 600
api_region: ‘eu’
2019-09-27 16:11:39 WARNING (MainThread) [homeassistant.loader] You are using a custom integration for sonoff which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you do experience issues with Home Assistant.
2019-09-27 16:11:42 ERROR (MainThread) [homeassistant.setup] Error during setup of component sonoff
File “/usr/src/homeassistant/homeassistant/setup.py”, line 168, in _async_setup_component
hass, processed_config
File “/config/custom_components/sonoff/init.py”, line 53, in async_setup
hass.data[DOMAIN] = Sonoff(hass, config)
File “/config/custom_components/sonoff/init.py”, line 108, in init
self.do_login()
File “/config/custom_components/sonoff/init.py”, line 192, in do_login
self.update_devices() # to write the devices list
File “/config/custom_components/sonoff/init.py”, line 357, in update_devices
if self.is_grace_period():
File “/config/custom_components/sonoff/init.py”, line 322, in is_grace_period
grace_time_elapsed = self._skipped_login * int(SCAN_INTERVAL.total_seconds())
File "/usr/src/homeassistant/homeassistant/setup.py", line 168, in _async_setup_component
File "/config/custom_components/sonoff/__init__.py", line 53, in async_setup
File "/config/custom_components/sonoff/__init__.py", line 108, in __init__
self.do_login()
File "/config/custom_components/sonoff/__init__.py", line 170, in do_login
self.do_login()
File "/config/custom_components/sonoff/__init__.py", line 192, in do_login
File "/config/custom_components/sonoff/__init__.py", line 357, in update_devices
File "/config/custom_components/sonoff/__init__.py", line 322, in is_grace_period
NameError: name 'SCAN_INTERVAL' is not defined
@MetalSpine terrible sorry for what happened to you but I hope you understand these kind of issues are not something I can fix/prevail (I still don’t understand why everyone keeps updating stuff if they’re working just fine as they are, especially when working in a hack-ish environment ¯\_(ツ)_/¯ ). in the same time glad you sorted it out
(as a side note i’m thinking to completely remove the sensor support from this component to avoid people creating important actions leveraging on not-so-safe reporting. not the best idea, but i guess better safe than sorry!)
I got the latest source code but still got an error
File "/config/custom_components/sonoff/__init__.py", line 101, in __init__
self.do_login()
File "/config/custom_components/sonoff/__init__.py", line 194, in do_login
File "/config/custom_components/sonoff/__init__.py", line 359, in update_devices
File "/config/custom_components/sonoff/__init__.py", line 324, in is_grace_period
grace_time_elapsed = self._skipped_login * int(self.get_scan_interval().total_seconds())
File "/config/custom_components/sonoff/__init__.py", line 104, in get_scan_interval
if self._hass.data[DOMAIN].get_debug_state():
KeyError: 'sonoff'
No apologies needed! Right after I hit update I instantly regretted it and thought I should have researched it first. Your code is still running all my other sonoff devices!
My pool and hot tub valves, pump, heater, air jets and lights all work automatically using your code for sonoff integration into home assistant.
a small bug was introduced by the time you probably tried it (sorry for that), but’s fixed now … i hope. not sure why but HA seems to behave slightly different on different environments
First of all great job!!! @peterbuga
I have an issue, that my sockets (S20 2 pieces) are is unavailable after a few mins, i updated the files to latest yesterday.
i created another account for ha and share the account from the main account, i’m using the second one that i created for HA.
This is the error from the log file:
2019-09-30 12:23:47 WARNING (MainThread) [custom_components.sonoff] Grace period activated!
2019-09-30 12:24:01 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from legacy took longer than the scheduled scan interval 0:00:12
2019-09-30 12:24:26 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from legacy took longer than the scheduled scan interval 0:00:12
2019-09-30 12:25:31 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from legacy took longer than the scheduled scan interval 0:00:12
2019-09-30 12:25:34 ERROR (Thread-7) [websocket] error from callback <bound method Sonoff.on_message of <custom_components.sonoff.Sonoff object at 0x7fe6efbb5490>>: string indices must be integers
2019-09-30 12:25:34 ERROR (Thread-16) [websocket] error from callback <bound method Sonoff.on_message of <custom_components.sonoff.Sonoff object at 0x7fe6efbb5490>>: string indices must be integers
2019-09-30 12:25:34 ERROR (Thread-10) [websocket] error from callback <bound method Sonoff.on_message of <custom_components.sonoff.Sonoff object at 0x7fe6efbb5490>>: string indices must be integers
2019-09-30 12:25:34 ERROR (Thread-19) [websocket] error from callback <bound method Sonoff.on_message of <custom_components.sonoff.Sonoff object at 0x7fe6efbb5490>>: string indices must be integers
2019-09-30 12:25:34 ERROR (Thread-13) [websocket] error from callback <bound method Sonoff.on_message of <custom_components.sonoff.Sonoff object at 0x7fe6efbb5490>>: string indices must be integers
2019-09-30 12:25:34 ERROR (Thread-25) [websocket] error from callback <bound method Sonoff.on_message of <custom_components.sonoff.Sonoff object at 0x7fe6efbb5490>>: string indices must be integers
2019-09-30 12:25:34 ERROR (Thread-2) [websocket] error from callback <bound method Sonoff.on_message of <custom_components.sonoff.Sonoff object at 0x7fe6efbb5490>>: string indices must be integers
2019-09-30 12:25:34 ERROR (Thread-22) [websocket] error from callback <bound method Sonoff.on_message of <custom_components.sonoff.Sonoff object at 0x7fe6efbb5490>>: string indices must be integers
After the state changes to unavailable, i got the code below:
2019-09-30 12:46:29 ERROR (Thread-16) [custom_components.sonoff] websocket error: Connection is already closed.
2019-09-30 12:46:31 ERROR (Thread-16) [custom_components.sonoff] websocket error: 'NoneType' object has no attribute 'is_ssl'
2019-09-30 12:46:31 ERROR (Thread-10) [custom_components.sonoff] websocket error: [Errno 9] Bad file descriptor
2019-09-30 12:46:32 ERROR (Thread-16) [custom_components.sonoff] websocket error: 'NoneType' object has no attribute 'is_ssl'
2019-09-30 12:46:33 ERROR (Thread-10) [custom_components.sonoff] websocket error: [SSL: DECRYPTION_FAILED_OR_BAD_RECORD_MAC] decryption failed or bad record mac (_ssl.c:2508)
2019-09-30 12:46:33 ERROR (Thread-16) [custom_components.sonoff] websocket error: [SSL: WRONG_VERSION_NUMBER] wrong version number (_ssl.c:1076)
2019-09-30 12:46:34 ERROR (Thread-10) [custom_components.sonoff] websocket error: 'NoneType' object has no attribute 'is_ssl'
2019-09-30 12:46:35 ERROR (Thread-16) [custom_components.sonoff] websocket error: [SSL: DECRYPTION_FAILED_OR_BAD_RECORD_MAC] decryption failed or bad record mac (_ssl.c:2508)
2019-09-30 12:46:35 ERROR (Thread-10) [custom_components.sonoff] websocket error: [SSL: CERT_LENGTH_MISMATCH] cert length mismatch (_ssl.c:1076)
2019-09-30 12:46:36 ERROR (Thread-10) [custom_components.sonoff] websocket error: 'NoneType' object has no attribute 'is_ssl'
2019-09-30 12:46:37 ERROR (Thread-10) [custom_components.sonoff] websocket error: [SSL: WRONG_VERSION_NUMBER] wrong version number (_ssl.c:1076)
2019-09-30 12:46:37 ERROR (Thread-16) [custom_components.sonoff] websocket error: [SSL: DECRYPTION_FAILED_OR_BAD_RECORD_MAC] decryption failed or bad record mac (_ssl.c:2508)
2019-09-30 12:46:39 ERROR (Thread-10) [custom_components.sonoff] websocket error: 'NoneType' object has no attribute 'is_ssl'
2019-09-30 12:46:41 ERROR (Thread-19) [custom_components.sonoff] websocket error: Connection is already closed.
2019-09-30 12:46:51 ERROR (Thread-10) [custom_components.sonoff] websocket error: 'NoneType' object has no attribute 'connected'
2019-09-30 12:46:53 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from legacy took longer than the scheduled scan interval 0:00:12
2019-09-30 12:46:53 ERROR (Thread-22) [custom_components.sonoff] websocket error: Connection is already closed.
2019-09-30 12:47:03 ERROR (Thread-10) [custom_components.sonoff] websocket error: 'NoneType' object has no attribute 'connected'
2019-09-30 12:47:06 ERROR (Thread-22) [custom_components.sonoff] websocket error: 'NoneType' object has no attribute 'connected'
2019-09-30 12:47:08 WARNING (MainThread) [custom_components.sonoff] Grace period activated!
2019-09-30 12:47:11 ERROR (Thread-25) [custom_components.sonoff] websocket error: Connection is already closed.
2019-09-30 12:47:13 ERROR (Thread-25) [custom_components.sonoff] websocket error: 'NoneType' object has no attribute 'is_ssl'
2019-09-30 12:47:13 ERROR (Thread-22) [custom_components.sonoff] websocket error: [SSL: DECRYPTION_FAILED_OR_BAD_RECORD_MAC] decryption failed or bad record mac (_ssl.c:2508)
2019-09-30 12:47:13 ERROR (Thread-25) [custom_components.sonoff] websocket error: [SSL: WRONG_VERSION_NUMBER] wrong version number (_ssl.c:1076)
2019-09-30 12:47:16 ERROR (Thread-22) [custom_components.sonoff] websocket error: 'NoneType' object has no attribute 'is_ssl'
2019-09-30 12:47:19 ERROR (Thread-28) [custom_components.sonoff] websocket error: Connection is already closed.
2019-09-30 12:47:21 ERROR (Thread-28) [custom_components.sonoff] websocket error: 'NoneType' object has no attribute 'is_ssl'
2019-09-30 12:47:22 ERROR (Thread-22) [custom_components.sonoff] websocket error: [SSL: DECRYPTION_FAILED_OR_BAD_RECORD_MAC] decryption failed or bad record mac (_ssl.c:2508)
2019-09-30 12:47:22 ERROR (Thread-28) [custom_components.sonoff] websocket error: [SSL: WRONG_VERSION_NUMBER] wrong version number (_ssl.c:1076)
2019-09-30 12:47:23 ERROR (Thread-28) [custom_components.sonoff] websocket error: 'NoneType' object has no attribute 'is_ssl'
2019-09-30 12:47:23 ERROR (Thread-22) [custom_components.sonoff] websocket error: [Errno 9] Bad file descriptor
2019-09-30 12:47:25 ERROR (Thread-28) [custom_components.sonoff] websocket error: 'NoneType' object has no attribute 'is_ssl'
2019-09-30 12:47:25 ERROR (Thread-28) [custom_components.sonoff] websocket error: [SSL: UNEXPECTED_MESSAGE] unexpected message (_ssl.c:1076)
2019-09-30 12:47:25 ERROR (Thread-22) [custom_components.sonoff] websocket error: [SSL: DECRYPTION_FAILED_OR_BAD_RECORD_MAC] decryption failed or bad record mac (_ssl.c:2508)
2019-09-30 12:47:26 ERROR (Thread-28) [custom_components.sonoff] websocket error: 'NoneType' object has no attribute 'is_ssl'
2019-09-30 12:47:27 ERROR (Thread-22) [custom_components.sonoff] websocket error: [SSL: DECRYPTION_FAILED_OR_BAD_RECORD_MAC] decryption failed or bad record mac (_ssl.c:2508)
2019-09-30 12:47:27 ERROR (Thread-28) [custom_components.sonoff] websocket error: [SSL: WRONG_VERSION_NUMBER] wrong version number (_ssl.c:1076)
2019-09-30 12:47:28 ERROR (Thread-22) [custom_components.sonoff] websocket error: 'NoneType' object has no attribute 'is_ssl'
2019-09-30 12:47:29 ERROR (Thread-28) [custom_components.sonoff] websocket error: [SSL: DECRYPTION_FAILED_OR_BAD_RECORD_MAC] decryption failed or bad record mac (_ssl.c:2508)
2019-09-30 12:47:29 ERROR (Thread-22) [custom_components.sonoff] websocket error: [SSL: WRONG_VERSION_NUMBER] wrong version number (_ssl.c:1076)
2019-09-30 12:47:30 ERROR (Thread-28) [custom_components.sonoff] websocket error: 'NoneType' object has no attribute 'is_ssl'
