to put it bluntly the Sonoff RF Bridge is NOT SUPPORTED at all with the current component not matter the firmware version…
but there are some good news though a couple of persons donated recently to the project and per manifesto i used the funds to buy new sonoff devices to integrate. i picked a RF bridge and a motion detector (slightly bad news i had to pick the cheapest prices i could find and now I’m waiting for the shipment, for several weeks now). after i get it i’m going to start working on it, soo there’s some hope for you
@david78455 you read it wrong Sonoff RF is not Sonoff RF Bridge they are 2 different devices, google it!
also, there’s a mention in the foot of the compatibility table: just because there’s no yes in a specific box doesn’t mean it’s not working, it means no one reported back that it works 100% (meaning there is a high change that it works with a wider fw versions)
Thanks for all the work to get this intergrated, i’m trying to get the custom component Sonoff/eWeLink working as an automation with very little success
the custom component and switch creation works on the main lovelace ui,
when i go to set the automation up like below
Nothing happens when i manually trigger it.
I can’t find the switch in anything other sub menu than an action type-“Condition” condition type - “state”
and i have looked in the init .py to see if there were any other Attrib values for on/off
thank you for any pointers
from my automations.yaml
alias: Sunset Schedule for Outside lights
description: Switches on outside light when the sunsets
- event: sunset
platform: sun
condition: []
- condition: state
entity_id: switch.sonoff_1000796972
state: 'on'
You need to call the service “switch.turn_on” to turn on the switch.
Try this:
- id: '1571719032416'
- event: sunset
platform: sun
condition: []
- service: switch.turn_on
At least that’s how it works for me for many switches. Btw: Sonoff doesn’t like to toggle many switches at the same time, so if you plan to use an automation for more than one switch, you better use " - delay: 00:00:01" between each of them.
Not working for me, many failed attempts an entries in log on setup, won’t setup and halts HA.
HA LOG
2019-10-26 10:57:23 ERROR (MainThread) [homeassistant.loader] Error loading custom_components.sonoff. Make sure all dependencies are installed
File "/srv/homeassistant/lib/python3.8/site-packages/homeassistant/loader.py", line 346, in _load_file
module = importlib.import_module(path)
File "/usr/local/lib/python3.8/importlib/__init__.py", line 127, in import_module
return _bootstrap._gcd_import(name[level:], package, level)
File "<frozen importlib._bootstrap>", line 1014, in _gcd_import
File "<frozen importlib._bootstrap>", line 991, in _find_and_load
File "<frozen importlib._bootstrap>", line 975, in _find_and_load_unlocked
File "<frozen importlib._bootstrap>", line 671, in _load_unlocked
File "<frozen importlib._bootstrap_external>", line 783, in exec_module
File "<frozen importlib._bootstrap>", line 219, in _call_with_frames_removed
File "/home/homeassistant/.homeassistant/custom_components/sonoff/__init__.py", line 28, in <module>
import websocket
ModuleNotFoundError: No module named 'websocket'
for anyone familiar with alarm systems in HA and/or persons interested in RF Bridge integration I would appreciate if you help me to figure out how this should actually work
I upgraded my HA to v. 0.101, and now Sonoff custom component dosen’t work.
I get this from the log:
2019-10-31 12:03:44 ERROR (MainThread) [homeassistant.loader] Error loading custom_components.sonoff. Make sure all dependencies are installed
File "/usr/src/homeassistant/homeassistant/loader.py", line 346, in _load_file
File "/usr/local/lib/python3.7/importlib/__init__.py", line 127, in import_module
File "<frozen importlib._bootstrap>", line 1006, in _gcd_import
File "<frozen importlib._bootstrap>", line 983, in _find_and_load
File "<frozen importlib._bootstrap>", line 967, in _find_and_load_unlocked
File "<frozen importlib._bootstrap>", line 677, in _load_unlocked
File "<frozen importlib._bootstrap_external>", line 728, in exec_module
File "/config/custom_components/sonoff/__init__.py", line 10, in <module>
from homeassistant.util.async_ import run_coroutine_threadsafe
ImportError: cannot import name 'run_coroutine_threadsafe' from 'homeassistant.util.async_' (/usr/src/homeassistant/homeassistant/util/async_.py)'
Anyone else with this issue? or does anyone know how to fix?
