I’m looking for a advice on how to troubleshoot the Sonoff GK-200MP2-B integration with home-assistant.
I have setup the camera with the eWeLink app. This works fine.
Getting it working in Home-assistant, however, is another story
I added the following to my configuration.yml
file and restarted home-assistant
ffmpeg:
camera:
- platform: ffmpeg
input: rtsp://rtsp:[email protected]:554/av_stream/ch0
In home-assistant I can see the entity ID, but when I add a picture-entity card, I get no image
Here is where I’m getting on thin ice and I’m looking for help:
I suspect I am missing ffmpeg on my setup.
My Home-assistant runs in containers on a raspberry pi4 (with an external harddisk)
[email protected]:~ $ cat /etc/os-release
PRETTY_NAME="Raspbian GNU/Linux 10 (buster)"
NAME="Raspbian GNU/Linux"
VERSION_ID="10"
VERSION="10 (buster)"
VERSION_CODENAME=buster
ID=raspbian
ID_LIKE=debian
HOME_URL="http://www.raspbian.org/"
SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
[email protected]:~ $ docker ps
CONTAINER ID IMAGE COMMAND CREATED STATUS PORTS NAMES
ec0d0a99c256 esphome/esphome-hassio-armv7:1.16.2 "/init" 25 minutes ago Up 25 minutes addon_a0d7b954_esphome
e4e57caf9fc6 hassioaddons/node-red-armv7:7.2.11 "/init" 26 minutes ago Up 25 minutes addon_a0d7b954_nodered
baca32e63e23 homeassistant/armv7-addon-configurator:5.0.0 "/init" 26 minutes ago Up 26 minutes addon_core_configurator
753de5a1db90 ghcr.io/hassio-addons/grafana/armv7:6.3.5 "/init" 27 minutes ago Up 27 minutes addon_a0d7b954_grafana
6cc1e13eb486 ghcr.io/hassio-addons/influxdb/armv7:4.1.1 "/init" 27 minutes ago Up 27 minutes 0.0.0.0:8086->8086/tcp addon_a0d7b954_influxdb
82777366f494 homeassistant/armv7-addon-samba:9.3.1 "/init" 28 minutes ago Up 27 minutes addon_core_samba
d9d42edc1bd9 hassioaddons/glances-armv7:0.9.1 "/init" 28 minutes ago Up 28 minutes addon_a0d7b954_glances
e30684db1ceb homeassistant/armv7-addon-mariadb:2.3.0 "/init" 28 minutes ago Up 28 minutes addon_core_mariadb
4b223c3466a7 homeassistant/armv7-hassio-multicast:2021.04.0 "/init" 28 minutes ago Up 28 minutes hassio_multicast
9b3cf184a887 homeassistant/armv7-hassio-cli:2021.05.1 "/init /bin/bash -c …" 28 minutes ago Up 28 minutes hassio_cli
4eff73b521cb homeassistant/armv7-hassio-audio:2021.04.0 "/init" 28 minutes ago Up 28 minutes hassio_audio
6a265051ae18 homeassistant/armv7-hassio-dns:2021.04.0 "/init" 28 minutes ago Up 28 minutes hassio_dns
ab89b4275ef1 homeassistant/armv7-hassio-supervisor "/init" 2 days ago Up 29 minutes hassio_supervisor
b0be901462b0 homeassistant/armv7-hassio-observer:2020.10.1 "/init" 2 weeks ago Up 29 minutes 0.0.0.0:4357->80/tcp hassio_observer
f1cffe3639cb homeassistant/raspberrypi4-homeassistant:2021.2.3 "/init" 3 months ago Up 27 minutes homeassistant
I tried to understand the documentation at: FFmpeg - Home Assistant and I installed ffmpeg on the Raspberry pi. (should it not be added to one of the containers instead?) but that did not help
[email protected]:~ $ sudo apt list --installed | grep -i ffmpeg
WARNING: apt does not have a stable CLI interface. Use with caution in scripts.
ffmpeg/testing,now 7:4.1.6-1~deb10u1+rpt1 armhf [installed]
Any tips on how to troubleshoot this are greatly appreciated
chrisV
