Hi all
So I was having the same problem as mentioned above regarding the cameras not working after the firmware upgrade. Reconnecting… … … constantly, within Home Assistant. eWelink app worked as normal.
To top it off, my TP-Link Deco M4 mesh system decided to reset itself after a few power failures.
So, I had to recreate the Mesh system, and just couldn’t see my cameras on my network at all.
They connect to my Guest network broadcasting a 2.4Ghz signal.
Then after some tinkering within my TP-Link Deco App, I found a setting (where the cameras connect to my 2.4Ghz, broadcast off my Guest network - where I initially connected the cameras to) that said:
Allow Local Access (with on off toggle)
When enabled, your guests will be authorized to access your local network resources, for example, your files and other information stored on computers.
I had this turned off. As I turned it on… voila, working.
But that had me thinking… My Deco M4’s can broadcast 5Ghz and 2.4ghz at the same time, if set that way. Not just within the Guest SSID.
So I turned that on.
Went into the eWelink App
WiFi settings
Changed the WiFi to point to my normal SSID of my Deco M4’s
It rebooted and still working.
Therefore, I didn’t need to perform the Micro-SD card fix explained above.
Just had to make sure that my SSID that my cameras connect to aren’t restricted in any way in communicating to my network.
In closing, check your router that broadcasts your 2.4Ghz SSID, that your cameras connect to, has “similar” access as to what I explained above.
This is my fix. So thought I would share it. Might work for you but no guarantee.
I tried a few different scenarios and checks to make sure this wasn’t just flook before typing this.
Hopefully this helps. Merry Christmas and Great New Year to all!
