Sonoff GK200MP2B camera: how to change time(zone) of camera?
I know this is not a real Home-Assistant question, but as many of us use the Sonoff GB200MP2B, I thought to try my luck here.
I have this webcam but the time in the webcam is not correct. I tried “Sync Time” in the eWeLink app, it said “Success” but the time is still 6hr off. I assume it is in the wrong timezone.
Does anyone know how to change that? (I have done my due diligence on Google and in the eWeLink app, but could not find how to change the timezone)
thanks a lot,
chrisV
I’ve got the exact issue
Have you fixed it?
Hi Sashanymous,
no, unfortunately not. The problem is still there,
chrisV
This firmware will fix time zone issue:
Before following the【Instructions】, please make sure the “Model” in Setting page is “S-CAM” or “GK-200MP2-B”
【Instructions】
① Turn off the camera power
② Copy the BIN file in the compressed package to the root directory of the Micro SD Card
③ Insert the Micro SD Card into the camera
④ When the camera is powered on, it will automatically enter the upgrading status(The IR LED will always flash) and will be online again after the upgrade.
*Do not turn off the camera power during upgrading!!!
*If it fails to upgrade, please format the Micro SD Card in the camera settings page in eWeLink, and then repeat the above operations; Before formatting, please transfer important files from the Micro SD card.
