Sonoff IFan02 (Tasmota) MQTT Fan
I cant find the custom fan card in hacs i Know this is old post. I just updated 931 tasmota and it change from light to fan I know i can swap it back but don’t want to mix things up if i dont have to.
Which custom fan card are you referring to?
this one:
Has someone already converted their config to the new fan integration settings? There are some changes:
The 'payload_medium_speed' option near /config/fan.yaml:0 is deprecated, please remove it from your configuration
The 'speeds' option near /config/fan.yaml:0 is deprecated, please remove it from your configuration
The 'speed_command_topic' option near /config/fan.yaml:0 is deprecated, please remove it from your configuration
The 'speed_state_topic' option near /config/fan.yaml:0 is deprecated, please remove it from your configuration
The 'speed_value_template' option near /config/fan.yaml:0 is deprecated, please remove it from your configuration
Try this thread to see if it helps:
For anyone who wants the old speed list functionality reinstated…
I’ve requested that the old speed list options should be kept and I’ve had a suggestion from a dev that if a FR gets enough votes they would implement it.
Here is the FR. Please go there and vote it up.
It won’t need to be updated if that FR gets implemented.
OR just delete all that and use the Tasmota HA integration and Tasmota 9.3+.
It just works… No YAML at all…
Then you don’t have to fix it all for Percentage fan speed.
Thanks @emontnemery !!
I do use @finity 's fan control entity rows, however. (There is one for percentage fan speed as well that works awesome.)
Thanks for the fantastic contributions to the community!!
I could see using that for new installs but there are a lot of existing fans using older tasmota versions who would benefit from leaving the speed list as an option.
and yes I know I could update my iFan03 to use newer tasmota. But I just have a dislike for updating things like this if they still work. And it does if the speed list gets left in.
and there are still template fans out there that may still need speed lists to work more effectively especially with the voice assistants.
And since the HA core change would be dead simple to add them back because they haven’t been fully removed now is the time to ask for (and implement) this “change”.
but thanks for the support for my button control rows. :slightly_smiling_face:
That was a post from over a year ago so sure the projects and integrations have moved on and better then what was sujjected then, but at the time it worked well
I myself have moved on and my only devices left running tasmota are two iFan02 as I am testing a third with ESP-Home and shortly will move the other two
I also use other fan-control cards
