Upgraded HAOS to 12.0; Core: 2024.2.5
Sonoff Integration has failed to load with “Invalid config” notification.
Error logs shows:
Unexpected exception importing component custom_components.sonoff
Setup failed for custom integration ‘sonoff’: Unable to import component: Exception importing custom_components.sonoff
Anyone else experienced this issue? Fix/workaround?
Logger: homeassistant.loader
Source: loader.py:827
First occurred: 9:13:08 AM (1 occurrences)
Last logged: 9:13:08 AM
File "/usr/src/homeassistant/homeassistant/loader.py", line 827, in get_component
ComponentProtocol, importlib.import_module(self.pkg_path)
File "/usr/local/lib/python3.12/importlib/__init__.py", line 90, in import_module
return _bootstrap._gcd_import(name[level:], package, level)
File "<frozen importlib._bootstrap>", line 1387, in _gcd_import
File "<frozen importlib._bootstrap>", line 1360, in _find_and_load
File "<frozen importlib._bootstrap>", line 1331, in _find_and_load_unlocked
File "<frozen importlib._bootstrap>", line 935, in _load_unlocked
File "<frozen importlib._bootstrap_external>", line 994, in exec_module
File "<frozen importlib._bootstrap>", line 488, in _call_with_frames_removed
File "/config/custom_components/sonoff/__init__.py", line 28, in <module>
from .core import devices as core_devices
File "/config/custom_components/sonoff/core/devices.py", line 104, in <module>
PULSEWIDTH = spec(XPulseWidth, param="pulseWidth", enabled=False)
File "/config/custom_components/sonoff/core/devices.py", line 90, in spec
return type(cls.__name__, (cls,), {**cls.__dict__, **kwargs})
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 414, in __init__
wrap_attr(cls, property_name)
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 386, in wrap_attr
raise TypeError(f"Can't override {attr_name} in subclass")
TypeError: Can't override _attr_native_max_value in subclass
