Sonoff LAN stopped working on 2022.4.x
Upgraded to 2022.04.x, and Sonoff LAN stopped working. AlexxIT updated the HACS-integration a couple of days later to 2.4.7 to fix the issue, bssically converting of percentages for the previous steps of High/Med/Low.
This seems to have fixed it for other people, but for me it is still not working! When pressing a button to adjust speed, I get the error “Failed to call service fan/set_speed. Service not found”.
I am using it in combination with the HACS integration frontend " Fan Control Entity Row" GitHub - finity69x2/fan-control-entity-row: Provides a means to show a compact graphical control row for 2 or 3 speed fans in Home Assistant
Screen Shot 2022-04-12 at 23.13.55
The config I have in “configuration.yaml” is:
# eWeLink
# https://github.com/AlexxIT/SonoffLAN
sonoff:
  username: !secret sonoff_username
  password: !secret sonoff_password
  mode: local
  reload: always
The configuration I have in Lovelace is:
entities:
  - entity: light.formal_dining_light
    name: Formal Dining Light
  - entity: fan.sonoff_100099485c
    type: custom:fan-control-entity-row
    name: Formal Dining Fan
show_header_toggle: false
title: Formal Dining
type: entities
Any idea on what I am doing wrong? How do I fix this?
Have you tried the other one that he has in there that is not percentages? I had to try both and see which one works. I have a iFan04 and I had to use the percentages version maybe yours uses the other one? “Fan Mode Button Row” instead of “Fan Percent Button Row”?
Sorry, not sure I understand! Which integration? SonoffLAN or fan-control-entity-row?
where do I change?
There is another HACS frontend with the name I posted. Try installing the frontend and testing it. It is by the same guy.
Yep, that did the trick!
Removed “Fan Mode Button Row” and installed “Fan Percent Button Row”.
The updated configuration I have in Lovelace is:
entities:
    type: custom:fan-percent-button-row
type: entities
Thanks!
It now works again!
