Hi
I intend to use the Sonoff mini flash Tasmota as a garage to open the door. The idea to connect a closed door switch to terminals S1 and S2 so that the mini sends an MQTT message to the Home Assistant about the door status (closed - not closed). Using the Sonoff relay, I would like to control the opening and closing of the door using an analog relay connected to the door drive.
I have studied these topics:
and
and unfortunately my abilities are not enough for me to be successful in the project.
Is anyone willing to help?
Thank you.
What do I need to confuse in my code to make it work?
- id: '1624024642008'
alias: Turn off all lights
description: ''
- platform: mqtt
topic: "stat/tasmota_EA268D/RESULT"
condition:
condition: template
value_template: "{{ trigger.payload_json['Switch1']['ACTION'] == HOLD }}"
- service: light.turn_off
entity_id: light.little_house_lights
mode: single
I will add some pictures of the settings in Tasmota:
