Sonoff Mini R2
hello
use anyone here a Sonoff Mini?
i added this switch to my zigbee network, but i only can switch on with HA. switch off is only possible with my real light switch
my connection:
I’m not sure how they work but is therr an event passed to ha or a binary sensor flipped when the physical switch is pressed?
no.
over the phoscon ui isnt also not possible to toggle the light.
only the physical switch works
think, there was a big problem in HA / phoscon with this devices…
I just bought a sonoff Mini R2, to make it completely local. should i still do those steps Flash ESPHome on a Sonoff R2 Mini using OTA DIY mode - Random DiY Projects
or
sonoff has made it simpler to install ESPHome
Regards,
Chandy
Update: it works like a charm. Initially flashing was struck at 0%. so tried from a different laptop it worked right away. As of June 5th 2023, this above steps works :slight_smile:
