After successfully flashing the MiniR4 and resetting, the device constantly reboots. I am using the default config from the ESPHome Sonoff MiniR4 page. Even if I flash the unit with a blank config it still reboots constantly.
YAML file:
esphome:
friendly_name: Sonoff MiniR4
esp32:
board: esp32dev
framework:
type: arduino
# Enable logging
logger:
# Enable Home Assistant API
api:
encryption:
key: "xxxxxxxxxxxxxx"
ota:
password: "xxxxxxxxxxxxxxxxx"
wifi:
ssid: !secret wifi_ssid
ap:
ssid: "Sonoff-Minir4 Fallback Hotspot"
password: "xxxxxxxxxxx"
captive_portal:
# Device specific Config Begins Below #
status_led:
pin:
number: GPIO19
inverted: true
output:
# Physical relay on GPIO
- platform: gpio
pin: GPIO26
light:
- platform: binary
icon: mdi:ceiling-light-multiple-outline
restore_mode: restore_default_off
output: relay_1
binary_sensor:
- platform: gpio
pin: GPIO00
filters:
- invert:
- delayed_off: 50ms
on_press:
- light.toggle:
- platform: gpio
pin: GPIO27
filters:
- invert:
- delayed_off: 50ms
on_press:
then:
- light.turn_on:
on_release:
then:
- light.turn_off:
Logs:
rst:0x1 (POWERON_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
mode:DIO, clock div:2
load:0x3fff0030,len:1184
load:0x40078000,len:13132
load:0x40080400,len:3036
entry 0x400805e4
[I][logger:351]: Log initialized
[C][status_led:014]: Setting up Status LED...
[C][ota:473]: There have been 4 suspected unsuccessful boot attempts.
[D][esp32.preferences:114]: Saving 1 preferences to flash...
[D][esp32.preferences:143]: Saving 1 preferences to flash: 0 cached, 1 written, 0 failed
[I][app:029]: Running through setup()...
[C][light:035]: Setting up light 'relay_1'...
[D][light:036]: 'relay_1' Setting:
[D][light:041]: Color mode:
[C][wifi:038]: Setting up WiFi...
[C][wifi:051]: Starting WiFi...
[C][wifi:052]: Local MAC: 08:D1:F9:2D:AC:EC
ets Jul 29 2019 12:21:46
