Sonoff motion sensor SNZB-03p
Hey! Anyone try sonoffs new motion sensor, the SNZB-03p? I know the original one lots of people had issues with, wondering if anyone’s tested the new one and what their thoughts on it are?
Thanks in advance!
Not yet but they are based on the newer EFR32MG22 SoC and have later firmware so unless ITead/Sonoff screwed up the hardware design for firmware configuration then they work well enough.
Guess you or someone else posted same question on Reddit too, see replies there:
https://www.reddit.com/r/homeassistant/comments/1c14d0x/sonoff_motion_sensor_snzb03p/
Found a review from Mat of notenoughtech here:
Btw, also check out Sonoff mmWave Human Presence/occupancy Sensor SNZB-06P which can be better or worse depending on use case, or very good if combine both:
