Hi, I have tried searching but not had much luck.
What entities for the original NS Panel are visible in home assistant if flashed with custom ESPhome/Tasmota firmware please? I want to use the physical buttons for light relays, but I need an entity for HA if the lights are on or off. Thank you.
Welcome to HA
What does this mean?
Means I can’t type . I edited the original thank you.
As above though I want to know if there is a relay / switch entity, so if “on” I can toggle an additional relay elsewhere. Thank you.
Ok, that is certainly clearer. Yes you’ll get an entity in ha which shows the state of the nspanel switch.
Thank you. Ordered
