My hero That was perfect. Just have to go through the device menu>esphome and NOT ESPHome in the sidebar. Then the permission is available. Thanks so much!
I think it helped, yes. Thanks a lot mate!
I tried suggested change top the code, but now when I try to Validate i got following error:
INFO ESPHome 2023.10.1
INFO Reading configuration /config/esphome/nspkitchen.yaml...
ERROR Error while reading config: Invalid YAML syntax:
while parsing a block collection
in "/config/esphome/nspkitchen.yaml", line 28, column 5:
- id: !extend wifi_default
expected <block end>, but found '?'
in "/config/esphome/nspkitchen.yaml", line 30, column 5:
fast_connect: true
My yaml code look like this:
substitutions:
###### CHANGE ME START ######
device_name: "nspkitchen"
wifi_ssid: !secret wifi_ssid
wifi_password: !secret wifi_password
nextion_update_url: "http://192.168.15.30:8123/local/nspanel_eu.tft"
##### addon-configuration #####
## addon_climate ##
# addon_climate_heater_relay: "1" # possible values: 1/2
##### CHANGE ME END #####
packages:
remote_package:
url: https://github.com/Blackymas/NSPanel_HA_Blueprint
ref: main
files:
- nspanel_esphome.yaml # Core package
#- nspanel_esphome_advanced.yaml # activate advanced (legacy) elements - can be useful for troubleshooting
# - nspanel_esphome_addon_climate_cool.yaml # activate for local climate (cooling) control
# - nspanel_esphome_addon_climate_heat.yaml # activate for local climate (heater) control
refresh: 300s
##### My customization - Start #####
wifi:
networks:
hidden: true
fast_connect: true
##### My customization - End #####
Please try this:
wifi:
networks:
hidden: true
fast_connect: true
Just a word of advice for anyone struggling to flash the TFT firmware:
Do not - I repeat DO NOT - download the nspanel_xx.tft file with your browser via “Save as…” from the Github repo. Instead, download the entire repo via Github’s green “Code” button and choose “Download ZIP”. Extract the zip file and copy the included nspanel_xx.tft over to your Home Assistant.
Kudos to the community at the Smarthome Yourself discord, where I stumbled over the fix after a week of struggling to get the NSPanel to run.
Why not? I always do this no issues at all.
With Firefox on windows.
Downloading via “save as…” seems to work for most people. But for some - including me - it doesn’t. It was driving me bonkers for days and if the advice helps people experiencing the same issue, I’m happy.
Like others I had trouble updating my panel with the latest TFT. Ipersisted for a few days trying all the suggestions mentioned in thread (except installing the dev branch which I only just saw).
From looking at the logs, I would see a Connection reset by peer
error. This seemed to be caused by my WiFi network.
In the end what worked for me was directly connecting to the TFT serial connection and using the Nextion Editor to upload the TFT file. I followed this video and the upload worked first time taking only 2mins (with the baud rate set to 921600).
v4.1 - Call for beta testers: v4.1 - Call for beta testers · Blackymas/NSPanel_HA_Blueprint · Discussion #1251 · GitHub
v4.1 - Easier TFT transfer
Overview of noteworthy changes
- New Upload TFT engine
- Hardware restarts with button hold for 15s
- Support to
esp-idf
framework - Support to 921600 bps
- Font size for chips
- Short click to open Climate and Media Player
v4.1 - Easier TFT transfer · Blackymas/NSPanel_HA_Blueprint · Discussion #1255 (github.com)
New 4.1 is great! The new TFT speed at 921600 makes the worst part of updating, waiting a long for tft to upload, now bearable! I mention how I did I upgraded using the new blank_tft in the discussion.
4x nspanel.
Update according to the instructions.
1x panel ended in “error” when updating TFT.
After re -invoking the TFT update, everything OK.
Update 3 others was without a problem.
Thank you for your work.
sorry to disappoint, I’m trying to install v 4.1 and it has been a struggle,
I finally managed to install the yaml and then upload tft failed over and over,
here is some logging
20:38:30 [D] [script.upload_tft:091]
Try #1
20:38:30 [D] [script.upload_tft:092]
Setting Nextion protocol reparse mode to passive
20:38:30 [D] [main:2449]
Exit reparse
20:38:32 [D] [nextion_upload:145]
Nextion TFT upload requested
20:38:32 [D] [nextion_upload:146]
url: http://192.168.180.149/nspanel_eu.tft
20:38:32 [D] [nextion_upload:185]
Connected
20:38:32 [D] [nextion_upload:191]
Requesting URL: http://192.168.180.149/nspanel_eu.tft
20:38:32 [D] [nextion_upload:225]
Updating Nextion NX4832F035_011C...
20:38:32 [D] [nextion_upload:251]
Waiting for upgrade response
20:38:32 [D] [nextion_upload:257]
Upgrade response is [05] - 1 bytes
20:38:32 [D] [nextion_upload:260]
Available 0 : 0x05
20:38:32 [D] [nextion_upload:264]
preparation for tft update done
20:38:32 [D] [nextion_upload:292]
Allocating buffer size 65536, Heap size is 135348
20:38:32 [D] [nextion_upload:309]
Updating tft from "http://192.168.180.149/nspanel_eu.tft" with a file size of 7248068 using 65536 chunksize, Heap Size 67012
20:38:33 [D] [nextion_upload:113]
Uploaded 0.06 %, remaining 7243972 bytes
20:38:38 [D] [nextion_upload:123]
recv_string [08.00.00.00.00 (5)]
20:38:38 [D] [nextion_upload:113]
Uploaded 0.11 %, remaining 7239876 bytes
Uploaded 0.17 %, remaining 7235780 bytes
20:38:39 [D] [nextion_upload:113]
Uploaded 0.23 %, remaining 7231684 bytes
20:38:39 [D] [nextion_upload:320]
Heap Size 46992, Bytes left 7231684
20:38:39 [D] [nextion_upload:049]
Requesting range: bytes=16384-81919
in one scenario I was able to upload almost 5%. but not more.
now I’m trying to revert to the old tft upload process, hope that works.
This is interesting. I wouldn’t expect buffer bigger than 32768 bytes in this case. I will have to investigate.
Anyways, thanks for sharing even the bad experience… Those are the ones which will push us forward.
Some things I would suggest:
- Try the new
nspanel_blank.tft
. That is way smaller and will enable the 921600bps transfer for the big file, which is 3 times faster. (But requires additional configuration) - Change your framework to
esp-idf
temporarily for this transfer. That framework have a better memory management (which is probably the issue in your case).
Could you please share the ESPHome yaml used for this? I wanna duplicate this case here.
Please remove any sensitive info before sharing.
Here you find how to switch to esp-idf
: (EN) Customization · Blackymas/NSPanel_HA_Blueprint Wiki · GitHub
Although it suggests to flash via serial, it’s probably fine if you flash it wirelessly, transfer the file, then remove those lines and flash it back (with the default Arduino framework).
thnx,
using the old upload I was able to upload the _blank file, but still probaly I messed something up because I still couldn’t uploade the _eu file.
then I tried the new upload and _blank got stuck at 46%
my config is a bit of a mess,
but the main file is this:
substitutions:
device_name: "lamp-kamer-voor"
nextion_update_url: "http://192.168.180.149/nspanel_eu.tft"
packages:
base: !include .base.yaml
device: !include .nspanel.yaml
remote_package:
ref: main
files:
- nspanel_esphome_addon_upload_tft.yaml # Core package
refresh: 300s
external_components:
- source: github://cossid/tasmotadevicegroupsforesphome@main
components: [ device_groups ]
refresh: 10 min
device_groups:
- group_name: "bulbkamerachter" # Tasmota device group name
switches:
- relay_1
- group_name: "bulbkamervoor" # Tasmota device group name
switches:
- relay_2
switch:
##### PHYSICAL SWITCH 1 #####
- name: ${device_name} Relay 1
platform: template
restore_mode: RESTORE_DEFAULT_OFF
optimistic: true
on_turn_on:
then:
- lambda: |-
id(detailed_entity).publish_state("light.bulb_kamer_achter_bulb_kamer_achter");
id(disp1).goto_page("light");
id(disp1).set_component_text_printf("page_label", "Kamer achter");
id(disp1).set_component_text_printf("back_page", "home");
id(disp1).set_component_text_printf("icon_state", "\uF060"); // mdi:lightbulb - https://htmlpreview.github.io/?https://github.com/jobr99/Generate-HASP-Fonts/blob/e1428f346777be69440f6bb00f1698815cb525d4/cheatsheet.html
# - script.execute:
# id: refresh_relays
on_turn_off:
then:
- script.execute:
##### PHYSICAL SWITCH 2 ######
- name: ${device_name} Relay 2
platform: template
optimistic: true
on_turn_on:
then:
- lambda: |-
id(detailed_entity).publish_state("light.bulb_kamer_voor_bulb_kamer_voor");
id(disp1).set_component_text_printf("page_label", "Kamer voor");
id(disp1).set_component_text_printf("icon_state", "\uE502"); // mdi:lightbulb - https://htmlpreview.github.io/?https://github.com/jobr99/Generate-HASP-Fonts/blob/e1428f346777be69440f6bb00f1698815cb525d4/cheatsheet.html
# - script.execute:
on_turn_off:
then:
- script.execute:
##### Real Buttons######
- name: ${device_name} Real Left
platform: gpio
pin:
number: 22
restore_mode: ALWAYS_OFF
- name: ${device_name} Real Right
platform: gpio
pin:
number: 19
restore_mode: ALWAYS_ON
then .base.yaml
wifi:
# power_save_mode: NONE
# power_save_mode: HIGH
ap:
ssid: "${device_name}"
captive_portal:
# Enable logging
logger:
api:
encryption:
key: !secret api_encryption_key
reboot_timeout: 0s
ota:
safe_mode: true
reboot_timeout: 3min
num_attempts: 3
password: !secret ota_password
# on_error:
# then:
# - logger.log:
# format: "OTA update error %d"
# args: ["x"]
web_server:
port: 80
js_url: https://mydomain.duckdns.org:8123/local/esphome/v2/www.js
auth:
username: admin
password: !secret web_server_password
button:
- platform: restart
name: "${device_name} switch Restart"
icon: "mdi:restart"
in .nspanel.yaml I copied, core
removed wifi, ota and relay_1 and relay_2
(I’m not allowed to post the full body as this makes the message to big)
I will try esp-idf now,
i know the advantages, but the other component I’m using does not support it
I note in breaking changes “Play rtttl (esphome.xxxxx_play_rtttl
)” is deprecated.
While it can be added back for now with the advanced YAML, is there an intention going forward to not support using the piezo speaker in the NSPanel, or is this just a memory saving option for a possibly little used feature?
small update form my side,
using esp-idf
_blank went fine
_eu first attempt ended at 69.94%
then I updated bautrate to 921600
but that didn’t work at all,
reverted to 115200
tried again and secceeded,
now still 2 panels to go
edit: so either disabling the external component or esp-idf fixed the issue
This is just a memory saving with something we believe just a few people is using. I use the buzzer myself and have no plans to drop the support for that.
Every time you change the speed it takes about a minute for ESPHome to identify the proper baud rate to communicate with Nextion. In fact ESPHome is trying to communicate all the time with the new baud rate, while Nextion switches it’s baud rate every 30s (I think) until the communication is established.
So, give it some time and it should work.
By any chance you have the logs related to that try? I’d love to see what caused the issue.
