Another weird thing I noticed in the newer version is that a scene does not stay highlighted in the nspanel dash, it gets activated the scene it lights up on the panel and then goes grey again, it does not retain the active state, even though the scene is still in operation.
i will check - better way is to create a issue on GitHub
Yes I know, saw that in your github page, but long lost my GitHub login, so I never use that anymore.
And thank you!
As soon as the NS Panel boots I get a message “System Data ERROR!” and nothing else.
Yes, I created issue 329 as I couldn’t find an existing issue there with the same problem. I see you replied so I’ll have to search again.
and also “Model does not match” both indicate something failed during the TFT update, you could try to update the TFT again, most of the times this solves the issue.
Anyone know how to adjust the Time format from 24 to 12. I read the documentation and it stated it uses the time from HA. HA is based upon who is logged into the session. Is there a way to set the time globally for all users or specifically for the Blueprint that anyone could point me to?
Thanks!
You should be able to modify the format in the blueprint. At least that is how it works for dateformat. I think for time it’s the same
How do i enable the top menu? Ive only got Top Menu 04 (Optional)
How can i create room/page for blinds? I’m using aqara E1 shade roller.
E:ok, u have to press and hold so that the slider shows up. But it doesn’t show battery state
Hello i am new to all this i have followd mark watts guide on yt and come to the stage nspanel update TFT display it tok 24 hours and now all it says is system data error please can someone help me?
Backymas one question I use the original firmware US version in landscape mode, I noticed you only made the US portrait version, can I use the EU version or should I wait for someone to do a conversion? Thank you
I’ve used the EU version for a US landscaped and the only issue was the switches names in the incorrect position, but all the functionality was fine.
Maybe I can find some time this week to create a US landscape TFT based on the EU version… I will share here if I find some time.
Ok for now I will use the eu version, waiting for the landscape version. Thank you
Vielen Dank für die Blaupause!
Ohne die hätte ich mir nie ein NSPanel gekauft, das macht es so viel einfacher, vielen vielen Dank
Es hat alles soweit funktioniert, klar hier und da hakt es manchmal, aber das sind Kleinigkeiten
Perfect, everything is ok and as edward says only problems with the position of the name of the switches. Now another question I have another nspanel in the drawer always US and always in landscape but flashed with jobrown’s tasmota/berry and I would like to convert it to esphome… I have doubts about the procedure… should the blank tft file be flashed via tasmota? and the esphome firmware can always be flashed from tasmota without having to do the procedure with the pins?
Yes!
Yes!
Danke wie immer wenn es gefällt freuen wir uns natürlich über eine Donation
thank you for being so active here - I am currently very busy with release 3.2
hi, my device cannot connect to wifi. I tried to connect to the hotspot that creates the device but it asks me for a username and password. Which should I use?
Sorry for my English
Thank you
