Hi, I am trying to get this to work but I am unable to upload the TFT file. I have the nspanel1 device available in HA and I can see the temperature for instance. I can also switch the Relays and this is all working. But when I press the nsp1 TFT Upload function nothing happens on the panel. Only thing I notice is that after about 10 seconds the NSpanel becomes unavailable, looks like it reboots. Any ideas?
If you change the filename in the secrets file of ESPHome, you have to reinstall the firmware of NSPanel in order to get the new filename reference.
To check that you have the correct location, put the link into a browser page.
Hi, My nspanel flashed with esphome is also stuck on the âSystem Data Errorâ screen and if i flash tasmota nothing happens it is not booting. When trying to flash the screen directly it start then just timeouts, any ideas? Do you have the stock tft?
For those beta testing the EU Widget UI, Iâve just uploaded the latest (2022-07-04 beta) version. It has improvements to the gestures (and the popup indicator for feedback) and tighter local coupling between the ESP32 and Nextion.
Thanks to @zigomatic for testing and fixing a problem with âcoverâ (blinds etc.) card (where the official documentation seems to be incorrect).
The ESPHome configuration has also had some improvements so you will need to update all 3 files this time (TFT, Python script and ESPHomne config template). Instructions for updating from a previous version are included at the top of the beta page.
just a thought but couldnât we use the log file to get around some of the partition size limits for the panel by not creating functions in the nspanel yaml but using HA with a folder watcher to execute automations? that way you are only using the yaml to populate info from HA to the nextion display? I have noticed that if you create an empty button on the display the log does pick it up. code or no code.
One suggestion I make that differs from what @zigomatic noted, is that it is much easier to rename the TFT file after downloading it each time to match the configured tft_url: rather than changing that part of your ESPHome configuration each time.
(The reason I have to rename the TFT file each time is that Nextion uses binary file formats that are not friendly for version tracking on GitHub, whereas the Python and YAML files keep the same file names and GitHub tracks the history of changes across updates.)
Here is my attempt in creating a custom gui and configuration for my NSPanel, flashed with esphome.
Some interesting features I managed to add are:
sliders for red, green and blue colors seperately, that update dynamically both ways,
brightness and color temp sliders
dual state buttons, that also update dynamically both ways
Most of the code is commented out, since I was facing bootloops after adding too many components, so I removed as much processing as i could from the esp module itself and passed it to HA to handle.
If you need any more info or my automations code in HA, please let me know.
Hope this inspires you to build your own, and apologies to all those great guys whose code I adjusted for my enfiguration, if I havenât mentioned anyone in my file.
Using the nextion platform with page id and component id will use up all the memory quick.
Itâs far better to use a variable in the screen and just read the variable in ESP. That way one nextion platform section of the ESP code can handle an unlimited number of buttons on the screen.
Im sure youâre right, but I wonât bother modifying anything, at least for now. I see myself getting more NSPanels in the future, since it can control anything and has endless potential to be used in various cases. For exaple, apart from the lights, whith which i made some crazy scenarios, I use it to control warming bed blankets, fans, AC, even a small fountain in my yard.
So I can see myself placing a number of those in various places throughout the home, to control different electric appliances.
Thanks for your inputs though.
Btw, this lovelace gui for the device looks gorgeous, but Iâm finished for now.
Hi, I hope this is not a question already asked, in case I apologize: I would like to know the pros and cons of the two methods to modify the Nspanel - Tasmota and Esphome. Thanks in advance
Just to follow up briefly on previous replies, there are 3 places that code is needed to link NSPanels to Home Assistant, and there is a range of approaches that put the emphasis (particularly the opportunities for customisation vs precompiled/template files) on different parts:
Tasmota/ESPHome just covers the options for the firmware on the ESP32 chip on the NSPanel (which allows Home Assistant to communicate with the Nextion display, buttons, etc.);
The Nextion Editor lets you build custom user interfaces (HMI files that you compile to TFT binaries and flash to the separate Nextion display MCU), or you can use standard precompiled Nextion files;
Home Assistant needs a Python script, custom component, AppDaemon, and/or automations to handle and respond to messages from the Nextion display (via the ESP32).
The simplest approaches let you use template or precompiled files for everything (with minimal user input required), while more complex approaches let you customise every detail of the display graphics and interactions with HA to your specific needs (a better end result, but a lot more effort required).
So, how much customisation would you like to do (just listing the entities you want to use in a preconfigured Nextion UI, fully customised interface, or somewhere in between) and, if you want detailed customisation, where are you most comfortable editing code/configs (ESP32, Nextion Editor, or Home Assistant YAML/Python)?
Thanks for the detailed answer, I have already used the Nextion editor on some small nextion displays, Esphome I use it for various components, including the management of the aquarium. Honestly, I would like to use the Nspanel in the living room to manage / check various components of the house, an example of the management of the aquarium parameters verification in addition to the classic thermostat, the physical buttons only for the management of the 2 lights in the living room âŚ
I get system data error sometimes after an unsuccessful TFT upload. The solution for me that works every time is to upload a new TFT file. Not the same as the one that got me into trouble. Instead I use a super small basic TFT tile that I upload when this happens and it seems to solve the issue.
