jobraun
(Johannes Braun)
October 24, 2022, 4:08pm
1069
No, you can talk to the nextion display in the standard instruction set and do this, but it will break the normal communication, furthermore this would be way to slow and way to complex to handle on the backend side.
The lovelace project is using ~
seperated serial commands defined in tmSerial in the HMI Project with all required information to build a page.
Did you change the line in pages.py and include your cardGrid2 to the array and restart AppDaemon afterwards? Without seeing your code I cannot tell you whatâs missing. Maybe fork the project on github and push your changes, so I can see them.
jobraun
(Johannes Braun)
October 24, 2022, 4:12pm
1070
The template is the stuff pre-filled in the issue while creating it, just donât delete it and fill your stuff into the template.
esdcmc
(Enrico)
October 24, 2022, 4:36pm
1071
Thanks a lot.
Stupid of me: I kept looking for a tab or an option called TEMPLATE and could not find one.
Now I did what you said and managed to open the request
Chrisss
October 24, 2022, 6:02pm
1072
Ok i got my new Card working now, forgot to restart appdeamon⌠and i was able to make the button an crop image. Now when i press the Image/Button it flashes as long i press it then it goes off again.
tmLP.en=1
tTmp.txt=type1.txt
pageIcons.tTmp1.txt=tEntity1.txt
pageIcons.tTmp2.txt=entn1.txt
pageIcons.tTmp3.txt=bEntity1.txt
if(type1.txt=="shutter")
page popupShutter
this is myButton itz an Dual-state button
What do i need to add here that it stays on when the Lamp is on?
i looked on the on off button from the EntitiesCard but i dont know what to do
may you can tell what is missing
Edit: I just tryed it with the onoff Button and there it works ofc. Thx a lot for the Help i think now i can do what i wanted.
micaelaman
(Micaelaman)
October 24, 2022, 8:04pm
1073
Thanks! this was the only thing that worked when my panel got the pesky system data error.
ClaireRovic
(Claire Rovic)
October 24, 2022, 8:13pm
1074
That would be awesome - thanks. Can you send it to me through this forumn
Blackymas
(Blackymas)
October 25, 2022, 9:16pm
1076
hey - send me pls a private message
echopage
(riccardo)
October 26, 2022, 9:29am
1077
Hi Blackymas, I have the us version of the nspanel, but I use it in landscape mode, can I then safely use the file on github?
Blackymas
(Blackymas)
October 26, 2022, 4:42pm
1078
there is no difference in the code. My programming works with EU and US version.
Only the positions have to be adjusted to the US version.
I donât have the US version - I can give you the HMI.
All you have to do is move the graphics and functions to the new position.
Maybe someone gives me a US panel then I do it myself
Hey, I got it to work. Thank you for your help!
echopage
(riccardo)
October 27, 2022, 8:22pm
1080
Blackymas, another question: I have already installed the custom version of tasmota on the nspanel, to flash esphome can I use the tasmota commands after creating the bin file?
htpc2308
(lulu)
October 30, 2022, 10:04am
1081
thank you.
now i try to use your new code with the icon in the popup, can you give a example? how to integrate ~icon~iconColor
to my actually code?
here is my actually code
CustomSend pageType~popupNotify; CustomSend entityUpdateDetail~id~{{ title
}}~65535~~~~~ {{ message }} ~65535~{{ timeout }}; Buzzer 2,2,2
and which format must icon have? mdi-lightbulb?
and the color is decimal?
i tried
}}~65535~~~~~ {{ message }} ~65535~{{ timeout }}~icon~mdi:alarm-light; Buzzer 2,2,2
but no luck
jobraun
(Johannes Braun)
October 30, 2022, 11:50am
1082
@htpc2308
}}~65535~~~~~ {{ message }} ~65535~{{ timeout }}~fontId~icon~iconColor; Buzzer 2,2,2
icon needs to be the the acual char, you can get the char by clicking U on the cheatsheet
https://docs.nspanel.pky.eu/icon-cheatsheet.html
iconColor needs to be the RGB565 Color in Decimal, here is a color picker for it:
https://docs.nspanel.pky.eu/notifications/#color-picker
resulting in something like this:
}}~65535~~~~~ {{ message }} ~65535~{{ timeout }}~0~î~2000; Buzzer 2,2,2
htpc2308
(lulu)
October 30, 2022, 1:38pm
1083
jobraun:
~î~2000
i tested it but with no luck, the icon is not visible, where you get the 2000? when i click for example on the ârecycleâ icon on the U, then i get this âîâ, but not the number ?
but your exa´mple doesnt works too, here is my code
}}~65535~~~~~ {{ message }} ~65535~{{ timeout }}~ď~; Buzzer 2,2,2
i installed the latest hacs release, and before i updated the tft file with this link
FlashNextion http://nspanel.pky.eu/lui-release.tft
jobraun
(Johannes Braun)
October 30, 2022, 2:59pm
1084
my example was wrong; edited the post
the number is the color of the icon; as I said color picker is here:
htpc2308
(lulu)
October 30, 2022, 3:06pm
1085
jobraun:
~0~î~2000
yeah that works well.
but, is it possible to add the {{ message }} under the icon ?
Or next to the icon?
This is all a bit confused, how you see here in my picture
jobraun
(Johannes Braun)
October 30, 2022, 3:15pm
1086
You can move the notification down with newlines (before the message) and you can change the font size aswell through the number before the icon.
Added some info about that to the docs.
htpc2308
(lulu)
October 30, 2022, 5:57pm
1087
thats perfect, great work!!
gives any other new function since the last update? or gives a page where i can look?
is it possible when iam under the icon with the message, to align it left?
jobraun
(Johannes Braun)
October 30, 2022, 6:32pm
1088
For already implemented features in the current dev version you can have a look to the next milestone.
Besides that cardPower is also already usable in current release, even though not finished.
no, thatâs not possible
