Sonoff P not finding anything
Hi Guys,
I am facing an issue with my brand new sonoff P dongle. I’ve installed 2mqtt and mosquitto, the app starts but impossible to find any device.
Do you have an idea why ?
Here is the log at starts :
What does your Z2M config look like?
  1. You’re enabling pairing in Z2M?
  2. You’ve put the device into pairing mode?
  3. The coordinator is on a USB extension cable (see here for why)?
  4. You’re using a Zigbee channel clear of all WiFi in the area?
  5. The devices are in range (max one wall and 8 meters away) of the coordinator or a working Zigbee router?
  1. You’re enabling pairing in Z2M? The device is in pairing mode
  2. You’ve put the device into pairing mode? yes
  3. The coordinator is on a USB extension cable (see here for why)? in the usb port on the back of the pi 5 (at 2 meters from the lightbulb)
  4. You’re using a Zigbee channel clear of all WiFi in the area? (default from the install)
  5. The devices are in range (max one wall and 8 meters away) of the coordinator or a working Zigbee router? yes
Try server: mqtt://core-mosquitto:1883
and an USB extension cable.
same story : here is the log : [11:11:06] INFO: Preparing to start... [11:11:06] INFO: Socat not enabled [11:11:07] INFO: Starting Zigbee2MQTT... Zigbee2MQTT:info 2024-04-05 11:11:08: Logging to console and directory: '/config/zigbee2mqtt/log/2024-04-05.11-11-08' filename: log.txt Zigbee2MQTT:info 2024-04-05 11:11:09: Starting Zigbee2MQTT version 1.36.1 (commit #unknown) Zigbee2MQTT:info 2024-04-05 11:11:09: Starting zigbee-herdsman (0.40.3) Zigbee2MQTT:info 2024-04-05 11:11:09: zigbee-herdsman started (resumed) Zigbee2MQTT:info 2024-04-05 11:11:09: Coordinator firmware version: '{"meta":{"maintrel":1,"majorrel":2,"minorrel":7,"product":1,"revision":20210708,"transportrev":2},"type":"zStack3x0"}' Zigbee2MQTT:info 2024-04-05 11:11:09: Currently 0 devices are joined: Zigbee2MQTT:info 2024-04-05 11:11:09: Zigbee: disabling joining new devices. Zigbee2MQTT:info 2024-04-05 11:11:09: Connecting to MQTT server at mqtt://core-mosquitto:1883 Zigbee2MQTT:info 2024-04-05 11:11:09: Connected to MQTT server Zigbee2MQTT:info 2024-04-05 11:11:09: MQTT publish: topic 'zigbee2mqtt/bridge/state', payload '{"state":"online"}' Zigbee2MQTT:info 2024-04-05 11:11:09: Started frontend on port 8099 Zigbee2MQTT:info 2024-04-05 11:11:09: MQTT publish: topic 'homeassistant/binary_sensor/1221051039810110150109113116116_0x00124b0029e8c51e/connection_state/config', payload '{"device":{"hw_version":"zStack3x0 20210708","identifiers":["zigbee2mqtt_bridge_0x00124b0029e8c51e"],"manufacturer":"Zigbee2MQTT","model":"Bridge","name":"Zigbee2MQTT Bridge","sw_version":"1.36.1"},"device_class":"connectivity","entity_category":"diagnostic","name":"Connection state","object_id":"zigbee2mqtt_bridge_connection_state","origin":{"name":"Zigbee2MQTT","sw":"1.36.1","url":"https://www.zigbee2mqtt.io"},"payload_off":"offline","payload_on":"online","state_topic":"zigbee2mqtt/bridge/state","unique_id":"bridge_0x00124b0029e8c51e_connection_state_zigbee2mqtt","value_template":"{{ value_json.state }}"}' Zigbee2MQTT:info 2024-04-05 11:11:09: MQTT publish: topic 'homeassistant/binary_sensor/1221051039810110150109113116116_0x00124b0029e8c51e/restart_required/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state","value_template":"{{ value_json.state }}"}],"availability_mode":"all","device":{"hw_version":"zStack3x0 20210708","identifiers":["zigbee2mqtt_bridge_0x00124b0029e8c51e"],"manufacturer":"Zigbee2MQTT","model":"Bridge","name":"Zigbee2MQTT Bridge","sw_version":"1.36.1"},"device_class":"problem","enabled_by_default":false,"entity_category":"diagnostic","name":"Restart required","object_id":"zigbee2mqtt_bridge_restart_required","origin":{"name":"Zigbee2MQTT","sw":"1.36.1","url":"https://www.zigbee2mqtt.io"},"payload_off":false,"payload_on":true,"state_topic":"zigbee2mqtt/bridge/info","unique_id":"bridge_0x00124b0029e8c51e_restart_required_zigbee2mqtt","value_template":"{{ value_json.restart_required }}"}' Zigbee2MQTT:info 2024-04-05 11:11:09: MQTT publish: topic 'homeassistant/button/1221051039810110150109113116116_0x00124b0029e8c51e/restart/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state","value_template":"{{ value_json.state }}"}],"availability_mode":"all","command_topic":"zigbee2mqtt/bridge/request/restart","device":{"hw_version":"zStack3x0 20210708","identifiers":["zigbee2mqtt_bridge_0x00124b0029e8c51e"],"manufacturer":"Zigbee2MQTT","model":"Bridge","name":"Zigbee2MQTT Bridge","sw_version":"1.36.1"},"device_class":"restart","name":"Restart","object_id":"zigbee2mqtt_bridge_restart","origin":{"name":"Zigbee2MQTT","sw":"1.36.1","url":"https://www.zigbee2mqtt.io"},"payload_press":"","unique_id":"bridge_0x00124b0029e8c51e_restart_zigbee2mqtt"}' Zigbee2MQTT:info 2024-04-05 11:11:09: MQTT publish: topic 'homeassistant/select/1221051039810110150109113116116_0x00124b0029e8c51e/log_level/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state","value_template":"{{ value_json.state }}"}],"availability_mode":"all","command_template":"{\"options\": {\"advanced\": {\"log_level\": \"{{ value }}\" } } }","command_topic":"zigbee2mqtt/bridge/request/options","device":{"hw_version":"zStack3x0 20210708","identifiers":["zigbee2mqtt_bridge_0x00124b0029e8c51e"],"manufacturer":"Zigbee2MQTT","model":"Bridge","name":"Zigbee2MQTT Bridge","sw_version":"1.36.1"},"entity_category":"config","name":"Log level","object_id":"zigbee2mqtt_bridge_log_level","options":["info","warn","error","debug"],"origin":{"name":"Zigbee2MQTT","sw":"1.36.1","url":"https://www.zigbee2mqtt.io"},"state_topic":"zigbee2mqtt/bridge/info","unique_id":"bridge_0x00124b0029e8c51e_log_level_zigbee2mqtt","value_template":"{{ value_json.log_level | lower }}"}' Zigbee2MQTT:info 2024-04-05 11:11:09: MQTT publish: topic 'homeassistant/sensor/1221051039810110150109113116116_0x00124b0029e8c51e/version/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state","value_template":"{{ value_json.state }}"}],"availability_mode":"all","device":{"hw_version":"zStack3x0 20210708","identifiers":["zigbee2mqtt_bridge_0x00124b0029e8c51e"],"manufacturer":"Zigbee2MQTT","model":"Bridge","name":"Zigbee2MQTT Bridge","sw_version":"1.36.1"},"entity_category":"diagnostic","icon":"mdi:zigbee","name":"Version","object_id":"zigbee2mqtt_bridge_version","origin":{"name":"Zigbee2MQTT","sw":"1.36.1","url":"https://www.zigbee2mqtt.io"},"state_topic":"zigbee2mqtt/bridge/info","unique_id":"bridge_0x00124b0029e8c51e_version_zigbee2mqtt","value_template":"{{ value_json.version }}"}' Zigbee2MQTT:info 2024-04-05 11:11:09: MQTT publish: topic 'homeassistant/sensor/1221051039810110150109113116116_0x00124b0029e8c51e/coordinator_version/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state","value_template":"{{ value_json.state }}"}],"availability_mode":"all","device":{"hw_version":"zStack3x0 20210708","identifiers":["zigbee2mqtt_bridge_0x00124b0029e8c51e"],"manufacturer":"Zigbee2MQTT","model":"Bridge","name":"Zigbee2MQTT Bridge","sw_version":"1.36.1"},"enabled_by_default":false,"entity_category":"diagnostic","icon":"mdi:chip","name":"Coordinator version","object_id":"zigbee2mqtt_bridge_coordinator_version","origin":{"name":"Zigbee2MQTT","sw":"1.36.1","url":"https://www.zigbee2mqtt.io"},"state_topic":"zigbee2mqtt/bridge/info","unique_id":"bridge_0x00124b0029e8c51e_coordinator_version_zigbee2mqtt","value_template":"{{ value_json.coordinator.meta.revision }}"}' Zigbee2MQTT:info 2024-04-05 11:11:09: MQTT publish: topic 'homeassistant/sensor/1221051039810110150109113116116_0x00124b0029e8c51e/network_map/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state","value_template":"{{ value_json.state }}"}],"availability_mode":"all","device":{"hw_version":"zStack3x0 20210708","identifiers":["zigbee2mqtt_bridge_0x00124b0029e8c51e"],"manufacturer":"Zigbee2MQTT","model":"Bridge","name":"Zigbee2MQTT Bridge","sw_version":"1.36.1"},"enabled_by_default":false,"entity_category":"diagnostic","json_attributes_template":"{{ value_json.data.value | tojson }}","json_attributes_topic":"zigbee2mqtt/bridge/response/networkmap","name":"Network map","object_id":"zigbee2mqtt_bridge_network_map","origin":{"name":"Zigbee2MQTT","sw":"1.36.1","url":"https://www.zigbee2mqtt.io"},"state_topic":"zigbee2mqtt/bridge/response/networkmap","unique_id":"bridge_0x00124b0029e8c51e_network_map_zigbee2mqtt","value_template":"{{ now().strftime('%Y-%m-%d %H:%M:%S') }}"}' Zigbee2MQTT:info 2024-04-05 11:11:09: MQTT publish: topic 'homeassistant/sensor/1221051039810110150109113116116_0x00124b0029e8c51e/permit_join_timeout/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state","value_template":"{{ value_json.state }}"}],"availability_mode":"all","device":{"hw_version":"zStack3x0 20210708","identifiers":["zigbee2mqtt_bridge_0x00124b0029e8c51e"],"manufacturer":"Zigbee2MQTT","model":"Bridge","name":"Zigbee2MQTT Bridge","sw_version":"1.36.1"},"device_class":"duration","entity_category":"diagnostic","name":"Permit join timeout","object_id":"zigbee2mqtt_bridge_permit_join_timeout","origin":{"name":"Zigbee2MQTT","sw":"1.36.1","url":"https://www.zigbee2mqtt.io"},"state_topic":"zigbee2mqtt/bridge/info","unique_id":"bridge_0x00124b0029e8c51e_permit_join_timeout_zigbee2mqtt","unit_of_measurement":"s","value_template":"{{ iif(value_json.permit_join_timeout is defined, value_json.permit_join_timeout, None) }}"}' Zigbee2MQTT:info 2024-04-05 11:11:09: MQTT publish: topic 'homeassistant/switch/1221051039810110150109113116116_0x00124b0029e8c51e/permit_join/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state","value_template":"{{ value_json.state }}"}],"availability_mode":"all","command_topic":"zigbee2mqtt/bridge/request/permit_join","device":{"hw_version":"zStack3x0 20210708","identifiers":["zigbee2mqtt_bridge_0x00124b0029e8c51e"],"manufacturer":"Zigbee2MQTT","model":"Bridge","name":"Zigbee2MQTT Bridge","sw_version":"1.36.1"},"icon":"mdi:human-greeting-proximity","name":"Permit join","object_id":"zigbee2mqtt_bridge_permit_join","origin":{"name":"Zigbee2MQTT","sw":"1.36.1","url":"https://www.zigbee2mqtt.io"},"payload_off":"false","payload_on":"true","state_topic":"zigbee2mqtt/bridge/info","unique_id":"bridge_0x00124b0029e8c51e_permit_join_zigbee2mqtt","value_template":"{{ value_json.permit_join | lower }}"}' Zigbee2MQTT:info 2024-04-05 11:11:09: MQTT publish: topic 'zigbee2mqtt/bridge/state', payload '{"state":"online"}' Zigbee2MQTT:info 2024-04-05 11:11:09: Zigbee2MQTT started! Zigbee2MQTT:info 2024-04-05 11:11:19: Zigbee: allowing new devices to join. Zigbee2MQTT:info 2024-04-05 11:11:20: MQTT publish: topic 'zigbee2mqtt/bridge/response/permit_join', payload '{"data":{"time":254,"value":true},"status":"ok","transaction":"ib4nz-1"}'
I don’t have any but what difference does it make ?
Do you have errors in your MQTT log?
You should see this…
here is the log
You need to enable joining in Z2M
Joining is enabled
I still think it is interference.
We should probably have him check, agreed?
I’d think it would pick up one device.
I have setup permit join still not finding anything
Indeed, such a long log in a screenshot is difficult to read.
I have a P and an E as well as a SLZB-06 and have never seen a log like this. Slightly stumped!
@Jo1216 There is a binary sensor button that keeps trying to join… What is that?
How may Zigbee devices are active?
The only thing I tried to connect is my light bulb
