I bought a generic tuya based Wall switch that can be controlled using RF or wifi. Upon installation, I noticed that whenever my sonoff pir sensor is triggered, my wall switch also triggers. Is there a way to fix this?
See if you can clear thé RF codes from thé tuya switch
Clear by resetting the tuya switch and not connecting to it with an RF remote controller?
I did a factory reset on the tuya switch, turned off the sonoff pir, paired the tuya app with the wall switch, then turned on the sonoff pir, it still affects the wall switch everytime sonoff pir senses a motion, the switch turns on or off
