Sonoff POW flashed with ESPHOME does not connect to WiFi, how to reach it?
Hi, I have many POW flashed with esphome and all work well. Just one since few days does not connect to WiFi … Now I want to access it, perhaps change the SSID in the yaml file to a closer WiFi AP. But since I can’t access what can I do?
I tried pressing 4 times fast the phisical swiotch (with tasmota it pouts it in AP mode), but this method is not working. Suggestions?
Well simple move the POW in an area better covered by AP it’s supposed to connect to or use your laptop to reflash it using USB adapter on it ! That’s a good idea to always set a default AP mode in your esphome yaml so if you don’t have anymore Wifi or wants to use it somewhere else you can still access the device with its local AP :wink:
ESPHome is not Tasmosta !! In ESPHome as explained above you can configure a default AP mode that’ll be activated if the device can’t connect at WIFI it’s supposed to !
its 5 meters to the router.
<That’s a good idea to always set a default AP mode
How to do this?
RTFM :wink: https://esphome.io/components/wifi.html#access-point-mode
