[Sonoff POW R1] Power measurements stopped working
Hi! :wave:
After recent updates I started noticing that the power measurements on my Sonoff POW R1’s have stopped giving any power measurements other than 0.0.
Example:
[13:49:15][D][sensor:118]: 'Socket Washer Wifi Strength': Sending state -73.00000 dBm with 0 decimals of accuracy
[13:49:45][D][sensor:118]: 'Socket Washer Wifi Strength': Sending state -72.00000 dBm with 0 decimals of accuracy
[13:50:15][D][sensor:118]: 'Socket Washer Wifi Strength': Sending state -71.00000 dBm with 0 decimals of accuracy
[13:50:37][D][sensor:118]: 'Socket Washer Power': Sending state 0.00000 W with 1 decimals of accuracy
[13:50:37][D][sensor:118]: 'Socket Washer Energy': Sending state 0.00000 Wh with 3 decimals of accuracy
[13:50:45][D][sensor:118]: 'Socket Washer Wifi Strength': Sending state -72.00000 dBm with 0 decimals of accuracy
[13:51:15][D][sensor:118]: 'Socket Washer Wifi Strength': Sending state -73.00000 dBm with 0 decimals of accuracy
[13:51:37][D][hlw8012:082]: Got power=0.0W, voltage=0.0V
This is my configuration:
substitutions:
  device_name: socket_washer
  friendly_name: Socket Washer
esphome:
  platform: ESP8266
  board: esp01_1m
  board_flash_mode: dout
wifi:
  networks:
  - ssid: !secret wifi_iot_ssid
    password: !secret wifi_iot_password
    hidden: true
  manual_ip:
    static_ip: 192.168.5.18
    subnet: 255.255.255.0
    gateway: 192.168.5.1
  ap:
    ssid: ${device_name} AP
    password: !secret wifi_ap_password
captive_portal:
# Enable logging
logger:
ota:
  password: !secret ota_password
  safe_mode: true
api:
switch:
  - platform: gpio
    pin: GPIO12
    restore_mode: ALWAYS_ON
  - platform: wifi_signal
    name: ${friendly_name} Wifi Strength
    update_interval: 30s
  - platform: hlw8012
    sel_pin: 5
    cf_pin: 14
    cf1_pin: 13
    current:
      unit_of_measurement: "A"
    voltage:
      unit_of_measurement: "V"
    power:
      unit_of_measurement: "W"
      device_class: power
      state_class: total_increasing
    update_interval: 60s
  - platform: total_daily_energy
    power_id: power
    unit_of_measurement: "Wh"
    device_class: energy
time:
  - platform: homeassistant
binary_sensor:
  - platform: gpio
    pin:
      number: GPIO0
      mode: INPUT_PULLUP
      inverted: True
    on_press:
      - switch.toggle: relay
  - platform: status
While I’d still need to calibrate them, before they were giving values, even if they weren’t accurate. Accuracy for me is not the main point, it’s mostly to trigger automations based on certain loads.
Other plugs based on the POW R2 using the cse7766 chip seem to have no issues at all.
Am I the only one experiencing this or is there anyone who has tips? Thanks!
