I installed home assistant 0.98.4 on raspberrypi 2. I configured the mqtt service in the raspberry pi and then I configured the configuration.yaml file.
It’s the config of the mqtt:
I configured shelly switch and yeelight in the same file and everthing works great. Yesterday I flashed tasmota for the sonoff pow R2 switch. I configured the mqtt service in the web interface:
I enabled the mqtt in the configure other option in the sonoff web inteface and I wrote friendly name.
Then I tried to config the sonoff in the configuration.yaml:
After I saved the configuration.yaml file I got an error in the home assistant:
ERROR (MainThread) [homeassistant.components.homeassistant] Component error: boiler - Integration boiler not found.
I established a MQTT broker. I set it up with this video: https://www.youtube.com/watch?v=Ce2Djxx9shU
I connected the HA to the broker in the configuration.yaml file and then I connected the sonoff to the broker in the web interface of the sonoff. I have a shelly switch that working with mqtt and everthing is ok. the sonoff doesn’t work
Ok it worked. Now I have another problem: In the home assitant UI i see the switch that I config in the configuration.yaml and I can switch it on and off but in addition i see another switch that called Sonoff that is not available for switching. How can I remove the Sonoff that not available?
Thank you it works great. I have another question: I have shelly switch and I have the sonoff switch. I want to add an option for my home assistant to update the firmware of the switches. Is there an option to do so in home assistant? How can I do it?
