This issue has been driving me crazy, hopefully someone knows how to help.
I flashed two identical Sonoff POW R2 devices with ESPHome. One for the washing machine and one for the tumble dryer. They both have the same configuration (except for the names). The washing machine reports all it’s values to Home Assistant, however when the tumble dryer does not.
When I look in the logs for the tumble dryer device it is reading the values:
[16:56:36][D][cse7766:147]: Got voltage=244.5V current=0.0A power=0.0W
[16:56:36][D][sensor:117]: 'Tumble Dryer Voltage': Sending state 244.47911 V with 1 decimals of accuracy
[16:56:36][D][sensor:117]: 'Tumble Dryer Current': Sending state 0.00000 A with 2 decimals of accuracy
[16:56:36][D][sensor:117]: 'Tumble Dryer Power': Sending state 0.00000 W with 1 decimals of accuracy
However the device entity shows it all as unavailable.
The configuration is as below:
esphome:
platform: ESP8266
board: esp01_1m
wifi:
ssid: "ssid"
password: "password"
ap:
ssid: "Tumble Dryer Esp"
captive_portal:
# Enable logging
logger:
baud_rate: 0
# Enable Home Assistant API
api:
password: "revaeb"
ota:
password: "revaeb"
uart:
rx_pin: RX
baud_rate: 4800
- platform: cse7766
current:
name: "Tumble Dryer Current"
voltage:
name: "Tumble Dryer Voltage"
power:
name: "Tumble Dryer Power"
switch:
- platform: gpio
name: "Tumble Dryer on-off"
pin: GPIO12
binary_sensor:
- platform: gpio
pin:
number: GPIO0
mode: INPUT_PULLUP
inverted: True
name: "Sonoff Basic Button Tumble Dryer"
on_press:
- switch.toggle: relay
status_led:
pin:
number: GPIO13
inverted: yes
I can see the logs and update it normally, just the last step of seeing the information in Home Assistant is causing the problem. I have tried deleting the entity and re-adding it but no luck - though I can see in the logs that it connects successfully:
[16:49:23][D][api.connection:630]: Client 'aioesphomeapi (192.168.0.14)' connected successfully!
[16:49:23][D][api.connection:630]: Client 'Home Assistant 2021.6.6 (192.168.0.14)' connected successfully!
Any help would be much appreciated,
C
