Hello, anyone been able to use the Sonoff POW R3 in home Assistant in LAN mode? The mode is enabled on eWeLink and on Home Assistant I am using the AlexxIT SonoffLAN integration but it still shows up as unavailable. Any pointers would be appreciated.
I would suggest to switch to Tasmota. Works flawlessly and POWR3 is very easy to flash.
Thanks, will give it a try tonight if I can find the usb flasher.
